| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
93 V6 into 90 4cyl.4Runner
#2 (permalink) |
I think if you go from a 22re to the 3vze you need different driveshafts.
As for the ECU, im sure it can be fooled to think its in neutral.
__________________
94 4runner / SR5 / 3vz-e / 5spd / 4x4 (duh) / Mudcat EXT 30x 9.5R15s / Marlin Crawler HD Clutch / ISR / Hella 700FFs 100w bulbs / 2 10'' JBL subs / ported sub box / kicker mono amp / Pioneer DEH-P490IB / sitting 1-1.5'' below factory, thanks butt sag... |
#3 (permalink) |
im thinkin the manaual trans will bolt up to the 3.0 i cant see why it wouldnt want to. wait why did he bring you all of that stuff all he needs is the motor ecu and harness. it sounds like he has brought u more stuff than what u need to do the swap with u might need a shorter drive shaft for the v6 but other than that. i might be way wrong but thats what im seein
__________________
1990 model SR5 3.0 automatic 3in bodylift 4in rough country liftkit. mods soon to come:new trans and transfer case, 35 or 36s, 5.29s and a lockrite, manual locking hubs |
#4 (permalink) |
Manual trans from the 4cy WILL NOT bolt up to the V6
You will need a R150 trans and transfer case that came from a V6 You will need to fabricate new motor mounts You will need a manual trans ECU and harness You will need a bigger radiator The swap is not worth it. The older 3vze V6 arent the greatest of engines. You would be MUCH better off swapping in a 3.4L 5vze. There is an entire forum dedicated to this swap right here on yotatech.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#5 (permalink) |
I think you need to tell the customer they are crazy. If they want to spend the money for you to do a custom engine install they might as well put in the much much better 3.4 from the 96 and up trucks/4Runners.
__________________
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE |
| Tags |
| 4runner, 90, 94, engine, harness, installing, swap, v6 |
