All Other Toyota Swaps I4, I6, Lexus V8
88 to 89 22re engine swap
Old 01-21-2015, 05:09 PM
mooselee's Avatar
I have a 1988 4x4 extra cab that needs an engine, and trans/t-case. I also have a 89 4x4 extra cab that is wrecked. My plan is to pull everything from the 89 as one unit, ecu included, and put in the 88. Does anyone see any issues i may have with wiring or anything else? Thank you.
Old 02-14-2015, 03:25 AM
8784 runner's Avatar
I assume the 88 was a RE as well?
If it is no wiring would be needed. Pull the shifter off your transmission and as long as you have a high enough hoist you can pull the whole drive train out in one piece and drop right into your other truck. Would be a 100% direct bolt in, as long as there both manuals of course. 2 people could easily do the swap in a solid day
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MMA_Alex
25
04-18-2017 05:07 AM
coryc85
09-09-2015 06:24 AM
God's Bounty Hunter
07-08-2015 12:54 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 88 to 89 22re engine swap
