All Other Toyota Swaps I4, I6, Lexus V8
86 pickup custom cab 2uzfe v8 swap
Old 05-18-2015, 04:18 PM
964runlim's Avatar
I started my build. It a 2006 toyota tundra 4.7 swap into an 1986 toyota pickup custom cab 4x4. Here are some pictures, will update as i go
Old 05-18-2015, 04:21 PM
964runlim's Avatar
Old 05-18-2015, 04:24 PM
964runlim's Avatar
i'm still trying how to load pictures will be more soon
Old 05-19-2015, 03:15 PM
964runlim's Avatar
Old 05-19-2015, 07:13 PM
egesledder's Avatar
Sweet truck! Any other pictures?
Good luck with the build, the 2UZ is a really nice motor.
Old 05-23-2015, 10:47 PM
964runlim's Avatar
pulling back out the finish welding exhaust.
Old 05-23-2015, 10:51 PM
964runlim's Avatar
here is a shot of the modified oil pan
had to weld in v band clamp because of space and easier to remove and install while in the truck
Old 05-23-2015, 11:09 PM
964runlim's Avatar
heat wraped the exhaust and reinstalled it back in, and should be the last time it comes out.
radiator to motor clearance, had to modified to radiator core support
i'm using 06 tundra auto transmission and to keep it passenger side drop I'm using low range adapter kit and a 1987 pickup transfercase
Old 10-12-2015, 06:37 PM
964runlim's Avatar
here is some updates. Had to redo to radiator so that i can run fans on the inside and have room in the front for a/c and transmission cooler.
looks like it hits but it over laps
Old 10-12-2015, 06:56 PM
964runlim's Avatar
Going to be using the 05 sequoia cluster and started on wiring.
Got exhaust done
front driveshaft on had pound to transmission pan a little to clear it
i about 90% done. Hopefully start some time this week will try to get a video of it started up
What i need left is a steering with column shifter,shifter cable,and bench seat. My truck was originally manual and am converting to auto. I been looking for awhile now with no luck. Let me know if anyone has these parts.
Old 11-21-2015, 04:47 PM
964runlim's Avatar
Finally started it.. The wire was a mess but got though it. will post videos later
Old 11-21-2015, 05:21 PM
964runlim's Avatar
[YOUTUBE]
[/YOUTUBE]
[YOUTUBE]
[/YOUTUBE]
Old 11-21-2015, 05:26 PM
964runlim's Avatar
all washed up.
Old 11-25-2015, 05:56 AM
egesledder's Avatar
That's awesome! Congrats on the completion.
Old 11-29-2015, 04:27 PM
slacker's Avatar
cant seem to pin point that adapter on there site ? .. any help
Old 12-05-2015, 09:28 AM
964runlim's Avatar
i can't seem the to find it too. but it's the same one as mc
https://www.marlincrawler.com/transf...v8-drivetrains
Old 12-15-2015, 04:21 PM
slacker's Avatar
cool .. thanks
Old 01-15-2016, 06:00 PM
964runlim's Avatar
The truck runs great so far. Today i took the truck to get weighted and it comes in at 4300 lbs without driver. I will get some in cab and drive videos.
Old 03-16-2016, 10:44 PM
Sporkinator's Avatar
How much did this whole project cost you? I've got a '90 4runner i've been wanting to do this with for a while
Old 03-22-2017, 06:47 PM
964runlim's Avatar
Facebook Post
Quick Reply: 86 pickup custom cab 2uzfe v8 swap
