All Other Toyota Swaps I4, I6, Lexus V8
22RE to 7MGE swap radiator fitment HELP!
Old 06-03-2016, 04:00 AM
Corydude99's Avatar
I am swapping out my 22re to a 7MGE and need help choosing a radiator that will fit. Alot of the posts I see with this swap have hacked the core support up to make a radiator fit. I am trying to avoid that since this body is in perfect shape. I read in one post someone cut the AC portion off the crankshaft pulley to make more room since they were not using the AC anyway, but I can't find it again. Are these engines externally balanced? I see that there are aluminum aftermarket pulleys, so I am thinking that its not???? Any insight is much appreciated. Thanks!
Old 06-03-2016, 05:27 AM
nothingbetter's Avatar
The engine is externally balanced. Whatever you do, don't machine off the a/c pully of the balancer, and do not buy an aftermarket aluminum balancer. From what I remember there is one company that make a 2 pulley balancer that is balanced but it will cost you a pile of cash.
I'd say just cut the rad support and make a frame to hold your rad wherever you need it. That's what I had to do. I also have an electric pull fan in between the rad and engine and I have a solid 1/4" gap between my fan and balancer.
if you want pictures of my setup there should be some in my build up thread when I was building my intercooler.
Old 06-03-2016, 08:33 AM
offroadnutz's Avatar
I used the radiator out of a v6 truck for mine. It fit right into the stock location without any modification. I was not able to use a manual fan though, so I used the electric off the supra and mounted it in front of the radiator.
Old 06-03-2016, 12:35 PM
Corydude99's Avatar
I do plan on using a pusher fan. How did you run your radiator hoses with that setup? The inlet to thermostat positions seem like it wouldn't work. Do you have pics? I have done a frame off resto on this and the body is pristine so I would hate to cut up the core support.
Old 06-03-2016, 12:49 PM
Corydude99's Avatar
Old 06-03-2016, 01:46 PM
I am using the supra hoses with a little modifications (trimming) to fit. I will post pics tomorrow when I can.
No need to cut anything up as long as its not a turbo.
Old 06-04-2016, 04:05 PM
Here are the pics. Including the part number for the upper hose.
Old 06-07-2016, 09:29 AM
Corydude99's Avatar
What year truck is that from? I just ordered a V6 radiator for an 88 4runner and the inlet is on the passenger side.
Old 06-08-2016, 05:31 AM
So Ive been looking into this and noticed something odd on my end.. Here is the tag number on my radiator that I got from the radiator shop.
The part number is 231 0945 which, I noticed when doing research, correlates to a standard 4cy radiator. But the inlet and outlets are on the opposite sides of factory placement which allows me to use the supra hoses. So now I honestly dont know what I have. The guy at the radiator shop told me it was a "V6" radiator. But now Im thinking that when he "ordered" the "V6" radiator he actually swapped tanks from a different application and made one. So it looks like I have unknowingly been driving around for years with a modified 4cyl radiator.
Old 06-08-2016, 07:26 AM
Corydude99's Avatar
I wonder if this would work? anybody try this with a 7mge swap? http://www.cxracing.com/mm5/merchant...&Category_Code=
Old 06-08-2016, 01:12 PM
You could also have one made.
Old 07-01-2016, 11:56 AM
Corydude99's Avatar
I ordered the CX racing one I mentioned above. It fits perfect but the inlet will interfere with alternator, but I am going to put a 90 degree elbow there and it should be perfect.
towotaguy
3.4 Swaps
26
09-13-2016 04:06 PM
ianD
03-11-2016 01:13 PM
Hrddrvs
03-06-2016 05:46 PM
usmma2013
03-06-2016 07:52 AM
Quick Reply: 22RE to 7MGE swap radiator fitment HELP!
