1UZFE into 1980 Pickup
HI I'm start my swap into 1980 pickup , special thanks to RMA for his direcctions, and FSP fine stell product in San Jose CA.
The shifter next to the wiper control switch is my best option off Toyota previa giving good clearance on steering wile .
Lifting by Chevy 1500 rear life springs and up grade rear disk braques by Nissan maxima calipers whit e brake by wire works ok
Tnx the wiring dash its complete and I swap the factory cluster for the SC400 ,because is small and easy to install in the opening.https://db.tt/vfzKOndw
didn't work !
when you hover over a picture on photo bucket , it will bring up a little "tool" icon in the right top corner , if you click on that you'll see
there is a link code .. it says "direct link" ------ > click on that , it will copy it to your clip board , then click in the icon here on this board when your posting , the little picture
and then "paste" the image you copied by clicking on the left button on your mouse .
in any case .. that is frickin' cool dude !!
you don't need to use a service like photobucket to post your pictures.
You can use Yotatech's picture uploader.
info here:
https://www.yotatech.com/forums/f122/announcements.html
info here:
09-04-2015 09:27 AM
DrZero
18
07-24-2015 11:31 PM
