| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
| Thread Tools | Search this Thread |
#201 (permalink) | |||||
__________________
86 Pickup 4x2, Manual (Sold) 87 Extra Cab Pickup 4x4, Manual (Sold) 93 4Runner 4x4, Manual, 3.4 Swap In progress 90 4Runner 4x4, Manual, Blown 3.0 (Stripping out for parts then to become a trail rig/camping/fun truck) 94 Lexus SC400, 1UZ, magnaflow exhaust, after market headlights, bought for parts for the swap into the 90 4Runner |
#202 (permalink) |
depends on your transfer case , I used a 21 spline gear case so I also used the inchworm #300-0052
check this page out . http://www.inchwormgear.com/store/pr...caffc3c10597f8
__________________
'89 2wd X-tracab,W55,22re,My DD '94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD '88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907, XRC8, Homemade Roof rack.33x10.50,15 KM2 1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake,truetrac front. My swap thread http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/ |
#203 (permalink) |
Going off of their instruction sheet.
http://www.inchwormgear.com/store/in...iven_tcase.pdf Thats is for a 4cyl. transfer case and I thought you and I both had a V6??? But if this is what is working for you then I will go that route.
__________________
#204 (permalink) | |
Quote:
Im not using the original v6 chain (hydraulic ) case Im using a 21 spline gear case.
__________________
#205 (permalink) |
@ RMA: this place is a local (to me) salvage yard that deals specifically with Lexus. I've been by there many times when i had my 90 LS. they may be able to help you find a decent EGR tube.
http://www.sportsandimport.com/
__________________
88 4Runner DLX, 15x8 soft8s w/ BFG 33x10.5 A/Ts. 1.5" SDORI spacers, OME CS009s, 1" 4crawler b.l., original Canback top |
#206 (permalink) | |
Quote:
THanks , I already found one , just waiting for it to arrive.
__________________
#207 (permalink) |
Hello .
very interesting and detail project. I been doing research to do same to my 1988 4 Runner. I cant decide to go with Chevy 350 or Lexus v8. Just to fill you in on Ca emission testing at the referee station , the referee will do the following test , smog the truck on the dyno , will do complete inspection ,making sure you have all the emissions equipment on the truck from donating car, and also will set few codes manually , to see if the ecu will respond to the codes and check engine will light after doing so . When the truck passes all the inspection he will issue a plate that gets mounted on the door post with BAR reference or referee # on it. In the future when you go in for biannual smog check inspection the smog technician will enter the BAR label # from your door post , then he can proceed with smog check inspection. |
#208 (permalink) |
Thanks alot man !!
I have heard the same thing , never all together just pieces of what you just typed . I should be ok then . Will have to get a pre test done before I go see the ref , I just got my 2010 sticker last month so Im not in a big hurry right now. again thanks !! Good luck with yours also .
__________________
'89 2wd X-tracab,W55,22re,My DD '94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD '88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907, XRC8, Homemade Roof rack.33x10.50,15 KM2 1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake,truetrac front. My swap thread http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/ Last edited by RMA; 10-04-2009 at 08:22 AM. |
#209 (permalink) |
amazing built good work
#210 (permalink) |
Thanks Dude !!
__________________
#211 (permalink) |
You got this swap done in a hurry. It's great to see just about everything working. A friend of mine put a 5VZ engine in his 4Runner and is happy but he wishes he had a 1UZ into it. The only benefit of him using the 5VZ over the 1UZ is that he passed the smog process without a problem. =]
#212 (permalink) |
Whats Up Smitherz , I really dont see a problem passing smog , especially once im done with the Ref.
Why do you think it is easier to pass smog with a 5vze , or am I reading this wrong.
__________________
#213 (permalink) |
Hey just got back from the American LeMans race up in Monterey. Need to make some time to give my project some attention later on today. I don't want to talk about smog because it's all up to your local smog ref (and DMV) and how nice he or she wants to be to you. Every area is different and every persons truck is a different situation! I don't think there is any recipe for passing smog or not passing smog. I've heard all sorts of things and I've seen a friend get papers for his engine swap (not Toyota or Lex) without the DMV lady even walking outside to look at it. Just keep all the factory smog equipment on it and just about anything will pass I think. Being nice and playing stupid also helps.
#214 (permalink) |
Do you think you will run into problems with the stock v6 thirds?
And holy cow, I would love love love to have a 1UZ-FE in my 'runner. This swap is amazing. Good job, and good luck with getting it legal.
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler '88 4runner|22re|5spd|206K miles|Sold '93 single cab|22re|5spd|150K miles|Sold| Pro IFS |
#215 (permalink) | |
Quote:
and Thanks !! I have been driving this thing a bit , toyminator sold me an EGR tube I needed , now no more exhaust fumes in the cab. I really like the new power and torque, what a difference !!
__________________
#216 (permalink) |
Congrats
__________________
#217 (permalink) |
so cool man. 4.0L v8 in a 4runner sounds awesome! i plan on getting a 90/91 ext cab and swaping a 3.4 supercharged in here on some 31" bfg a/t's with a lsd rear for a DD and for some fun to drive heh. i would like the v8 but figure for me the 3.4 is better lol. that v8 would be nice on the hills unlike my 22re though haha. you have my respect for taking a big project like this cheers!
__________________
91 std cab,4wd, 22re, 5spd, 31" Dick Cepek mud country's, dimond plate in box. "open diffs SUCK" |
#218 (permalink) | |
Thanks Again!! Quote:
I have her parked right now and am building a rear bumber and sliders.(well trying to atleast). I am also swaping a LT1 along with the six speed into an automatic 1966 lemans for a friend of mine and have a 1963 Impala waiting in the wings for an LS1 with the six speed . already mounted the engine and tranny in the lemans , now working on the wiring. once my friends saw the truck finished they were coming out of the wood work wanting swaps done . ![]() Ill post pics of the bumper and sliders when I get done with them.
__________________
'89 2wd X-tracab,W55,22re,My DD '94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD '88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907, XRC8, Homemade Roof rack.33x10.50,15 KM2 1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake,truetrac front. My swap thread http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/ Last edited by RMA; 11-05-2009 at 06:00 PM. |
#219 (permalink) |
sounds sweet man. Hey if a had a friend who does as good as a job as you i would be asking him for help too lol. cant wait to see bumper and sliders
__________________
#220 (permalink) |
Hi there,
I have had a really good read here about this mod of yours. 1st congrats on the rebuild, you will be very happy with the power the engine puts out, i am a V8 addict and have been for many years. I have used an Australian engine in mine and it is a 5.7ltr with a T700 behind it, and I did like you sat there and worked it out on my own in many places. I found it just makes you feel good about your achievement. I also modified my dash and changed instruments as well. mine is on another rebuild, still using the Holden engine but I too have gone for the fuel injection setup, and I can't wait to go bush with it again. once again congrats, and enjoy yourself it will be a ton of fun.
#221 (permalink) | |
Quote:
Thank alot Man !! I read thru your build and really liked the shower you installed , may have to do that to mine . I am surprised you didnt go with the 1uz , almost all the info I was reading before my swap was coming out of austraila.But hey what ever works for you , right. thanks again.
__________________
#222 (permalink) |
You are welcome, I decided to go with the Holden motor because I already had 3 of them at one stage sitting in my shed, and here they are everywhere, you can almost pick parts up for them at the rubbish tip, but I was seriously thinking about it. If I didn't have any of the Holden motors, I would have used the same engine as you have.
#223 (permalink) |
Hey RMA great work man everything looks great
How much would you say you spent on the whole thing so far (if its ok to ask) i would just like some sort of idea because i am looking into doing the same swap except into a 2nd gen but im going to need some help
__________________
-Robert 93 4Runner/3.0/5 Spd/4 inch rough country lift/35inch KM2s/Surco rack/4 4x warn spot lights/CB (ashtray mod)/2001 tacoma center console/ISR mod/350,xxx miles ---whatever it takes---
#224 (permalink) |
Hi there again, I have been scratching through your forum and found a guy that has done this mod to his vehicle, he is in Australia but he mat have some ideas as well for you. He is well known in one of the Australian forums and he is using the same name here as well, his user name is "Twisty" give him a look up, you might be happy with what he has done.
#225 (permalink) | |
Quote:
__________________
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE |
| Tags |
| 1986, 1988, 1uz, 1uzfe, 3vze, 4runner, 4x4, a341e, california, jose, lextremecom, pirate4x4, sale, san, site, swap |
