All Other Toyota Swaps I4, I6, Lexus V8
1jz gte vvti into 84 runner clutch ?
Old 02-23-2013, 05:41 AM
8784 runner's Avatar
So very soon i will be starting my swap with a 1jz turbo vvti going into my 84 runner. The motor will be here monday 2/25/13. The bellhousing that i will be using to bolt it to the tacoma trans will be here the following week. The only thing i cant seem to get a def yes or no by searching the supra forums is what flywheel/clutch setup i will need to use. Do i use the setup that came with 1j vvti r154 or can i now use the tacoma setup that came with the r150f which is the trans i will be using?................i signed onto a supra forum to post the same question but it's been 2 days and still waiting to be "approved" before i can post anything
Old 03-04-2013, 06:01 PM
schwyter's Avatar
you need to use the setup to match the engine
mskalmus
05-28-2017 07:51 AM
Kalihi,HI
07-09-2015 04:29 PM
Jnkml
07-06-2015 01:20 PM
coryc85
07-06-2015 04:07 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 1jz gte vvti into 84 runner clutch ?
