URD 7th and fuel line connection with swap
After running the larger injectors with a split second fuel controller I am stepping up (I hope) to the 7th from URD. Ran into an issue tonight, braided fuel line to connect in is too short. This information might already be out there and don't blast me if it already is but what did you other swappers do for this problem? I was thinking of trying to find another one out there somewhere but wanted to finish it up this weekend. Thoughts?
Got it on now is running awful
Fixed the fuel line and no issues with leaks but now runs terrible with the preloaded map from Gadget. I put on the 2.2 pulley and running the supra MAF. So I think it is a matter of manipulating the fuel maps. Does anyone have this setup (URD 7th, 2.2 and supra maf)? Or does someone at least have a 7th with the 2.2 pulley maps they could shoot me to start from. The car starts up and then it immediately runs horrible and finally quits.. It is going lean and being starved.. That is what it sounds like anyway. Can someone shoot me a map to start the tuning off with?
Good point.. I probably should stop this thread and switch to a new thread in the 3rd gen and tacoma section..
I wouldn't suspect you'd need that much more fuel to make it run decent. I would suspect a wire or two got crossed in the maf. Not sure if you rewired it or if its plug and play but somethings not right.
Also not sure what your power goals are but I'm running 14-15lb boost thru factory maf and using tiny 1.5" charge pipe. Your stock maf is not restrictive at your power levels.
Issue Resolved
Resolved the issue this morning. I realized after victors post that with the 7th injector controller it does not control or manipulated the mass air flow and therefore the Supra MAF will require additional electronics to run correctly. The FTC i had on there did control through the MAF so it was just a plug and play. I verified this through Gadget. She runs beautiful now and the boost is amazing with the 2.2 vs stock pulley. And I am sure the 7th helps over the supra injectors. It is fun to drive.. Thanks for your help!!
Now I just need to figure out how to do the heater control valve. Supercarger is so big that I can't open all the way to let flow out. Has anyone changed it out so that it is thiner or moved somehow out of the way so it is free to move in and out?
steve miller
10-10-2015 01:40 AM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
TURBOrunnerNM
07-22-2015 11:01 AM
