Tyco Electronics ECU Connector Part Numbers
Old 12-01-2015, 05:40 PM
SacRunner's Avatar
Long story short, while chasing an electrical bug, I decided to replace a couple of the terminals and connector housings with my swap and rather than spend the $$ that Toyota wants for housings and new wire ends, I went out and found the actual manufacturer's part numbers.
These were originally made by AMP, but somewhere along the lines Tyco Electronics bought AMP, so now they're Tyco (TE) parts. Some still have "AMP" molded in the housing, the newer ones have "TE" molded.
This is all based on the 96/97 4Runner 5VZ EWD, but I seem to recall that the 3 row connectors were used in later model 5VZs.
I couldn't add an actual table, so this is the closest I cared to get, but imagine the following data as a table, with headers "URL," "Part Number," and "Color." I included information about the crimp on terminals that are needed, at the bottom.
E5 (A) - 26 pin female - 90980-11390 (pitch 3, 3.5 mm, mating tab width 1, 1.8 mm)
http://www.te.com/usa-en/product-917992-1.html 917992-1 White
http://www.te.com/usa-en/product-6-917992-6.html 6-917992-6 Light Gray
http://www.te.com/usa-en/product-917992-6.html 917992-6 Dark Gray
http://www.te.com/usa-en/product-917992-7.html 917992-7 Yellow
http://www.te.com/usa-en/product-917992-2.html 917992-2 Black
http://www.te.com/usa-en/product-917992-5.html 917992-5 Blue
E6 (B) - 16 pin female - 90980-11391 (pitch 3 mm, mating tab width 1 mm)
http://www.te.com/usa-en/product-917981-1.html 917981-1 White
http://www.te.com/usa-en/product-917981-2.html 917981-2 Black
http://www.te.com/usa-en/product-917981-6.html 917981-6 Dark Gray
http://www.te.com/usa-en/product-917981-7.html 917981-7 Yellow
E7 (C) - 12 pin female - 90980-11408 (pitch 3 mm, mating tab width 1 mm)
http://www.te.com/usa-en/product-917975-1.html 917975-1 White
http://www.te.com/usa-en/product-917975-2.html 917975-2 Black
http://www.te.com/usa-en/product-917975-6.html 917975-6 Dark Gray
http://www.te.com/usa-en/product-917975-7.html 917975-7 Yellow
http://www.te.com/usa-en/product-6-917975-6.html 6-917975-6 Light Gray
E8 (D) - 22 pin female - 90980-11392 (pitch 3, 3.5 mm, mating tab width 1, 1.8 mm)
http://www.te.com/usa-en/product-917989-1.html 917989-1 White
http://www.te.com/usa-en/product-917989-2.html 917989-2 Black
http://www.te.com/usa-en/product-917989-5.html 917989-5 Blue
http://www.te.com/usa-en/product-917989-6.html 917989-6 Dark Gray
http://www.te.com/usa-en/product-917989-7.html 917989-7 Yellow
http://www.te.com/usa-en/product-6-917989-6.html 6-917989-6 Light Gray
E9 (E) - 34 pin female - 90980-11221 (pitch 3.6 mm, mating tab width 1 mm)
http://www.te.com/usa-en/product-316022-1.html 316022-1 White
http://www.te.com/usa-en/product-316022-6.html 316022-6 Dark Gray
E10 (F) - 22 pin female - 90980-11220 (pitch 3.6 mm, mating tab width 1 mm)
http://www.te.com/usa-en/product-316016-1.html 316016-1 White
http://www.te.com/usa-en/product-316016-6.html 316016-6 Dark Gray
E11 (G) - 16 pin female - 90980-11219 (pitch 3.6 mm, mating tab width 1 mm)
http://www.te.com/usa-en/product-316013-1.html 316013-1 White
http://www.te.com/usa-en/product-316013-6.html 316013-6 Dark Gray
E12 (H) - 28 pin female (90980-11218)
nothing from Tyco Electronics
Terminals:
http://www.te.com/usa-en/product-175265-1.html 1 mm Tin
http://www.te.com/usa-en/product-175266-2.html 1 mm Gold
http://www.te.com/usa-en/product-175266-7.html 1 mm Gold
http://www.te.com/usa-en/product-175268-1.html 1.8 mm Tin
http://www.te.com/usa-en/product-175269-1.html 1.8 mm Gold
F-crimp crimp tool is needed to properly crimp the terminals.
You're on your own to find a site to buy these, but in general, I've had good luck with www.mouser.com/, www.digikey.com/, and www.jameco.com/ but I haven't checked that they all carry these.
Enjoy!
EDIT:
Here's a picture of the connectors from the EWD
The following users liked this post:
BigBluePile (12-03-2021)
Old 03-28-2016, 02:17 PM
drnut's Avatar
I have been searching high and low for this thread! This is the only place I have seen all the information together, thanks for posting it up!
ECU Plug connectors, I know some people are looking for this as well. I vote sticky!
Old 03-29-2016, 05:54 AM
Cadin's Avatar
Certainly Sticky has my vote as well! SacRunner thankee for thine work!
Old 12-03-2021, 06:31 PM
BigBluePile's Avatar
Just what I needed!
MudHippy
02-07-2016 08:02 AM
Gonzo_Yota
06-04-2015 06:32 PM
024RunnerSE
07-27-2014 01:32 PM
Scofco
03-30-2008 10:35 PM
Gavin S.
08-10-2005 07:01 AM
Quick Reply: Tyco Electronics ECU Connector Part Numbers
