Tach Mod?
Tach Mod?
Ive searched high and low looking for an answer to which resistor to use. I know it is the 10K-Ohm resistor, but is it the 1/4 watt or the 1/2 watt resistor? Thanks for your time.
According to Voltage = Current * Resistance, assuming 12 volts and 10k ohms, your current through the resistor will be 1.2mA. Wattage is Voltage * Current, so 12*.0012 gives you 0.014 watts that will be dissipated through the resistor. That's 5.6% of the 1/4 watt resistors maximum power dissipation. So go with either one really, but the 1/4 will be fine.
Sorry to get all technical on you... I was studying for my Physics 2 exam when I ventured over here.
Oh and I haven't done the tach mod yet, but make sure you know whether you're wiring it in series or in parallel...it matters quite a bit!
How about 1/8 watt?
I'm starting to get really frustrated with how difficult it is to find something so simple and common..
Have a whole bag of 1/8 watt resistors and I'd really like to get the tach working!
0.125 > 0.014
You should be fine
TheBFA
02-15-2020 06:55 AM
