speedometer question on 1999 3.4 swap
I am swapping in a 1999 3.4 plus auto trans plus transfer case. I know they use an electronic signal for the speedo in the 99 but my 88 is mechanical. There is a hole in the transfer case with a bolted in plug and when I remove it I see the gear to drive a mechanical speedo. Where do I find the part to slip in the hole to run my mechanical speedometer. Any help would be greatly appreciated.
IIRC 88-91 V6 Manual transmission has the correct diameter sensor? As for whether it's the right ratio, can't say for sure.
Take the plug out and go to a local wrecking yard, start pulling speedo drive gears out of trucks/4Runners until you get one that matches up
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
