someone help this newb! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-29-2009, 07:56 PM   #1 (permalink)
ive looked throught this place and cant seem to find an easy answer i got a 92 sas'd 5 speed with a 3.0 that suuuucks. it needs a new better engine. i have two options, either pull the 4.3 tbi out of my 86 or pick up a rolled 4runner 3.4 manual for $500. im leanin towards the 3.4 but how hard is it gonna be if i just switch everything. will it swap easy or is there still alot of cut and splice. straighten me out or if you can point me in the right direction would be cool. ive done the 4.3 but im pretty new to toyotas.
azdirtdemon is offline
Old 09-29-2009, 08:00 PM   #2 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
http://www.yotatech.com/f160/
Read ALL the stickies at the top. That should answer all your questions and some you haven't thought of yet.
waskillywabbit is offline
Old 09-29-2009, 08:05 PM   #3 (permalink)
lostINtheSAUCE's Avatar
checkout the 3.4 swap section in the forum jump at the bottom of the screen
or use the link above
__________________
1990 4RUNNER 3.0 STOCK
1970 BUICK SKYLARK 350
2002 FORD ESCAPE
1967 GMC C-SERIES PICKUP
lostINtheSAUCE is offline
Old 09-29-2009, 08:23 PM   #4 (permalink)
olharleyman's Avatar
I am getting ready to do the same thing and as far as I know it's very cut and dry upto the wiring harness. You do need parts from the 3.0 for the 3.4 namely
oil pan,splash guard, pick up,sender,motor mounts,dip stick and tube and if it's a 2000 or newer 3.4 you need to redrill the oil dip stick tube hole to the rear and fill the front original hole.
throw out bearing,as for clutch,pressure plate and flywheel as far as I have read them 3 are pretty much interchangeable with most choosing to keep the 3.4 set up. Then the major pain in the after all that is the wiring,and if you have a 5 speed you need the 5 speed ecu auto you need the auto ecu or figure out how to trick the auto ecu into believing it's in neutral all the time.
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
88 stock 4runner
3.0 auto
for now
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
