And so it begins -- 95 3.0 -> 98 3.4
I just posted a couple pictures that should help clarify
https://www.yotatech.com/forums/f12/.../#post52197675
oil pressure sensor connector broke
Pretty sure you can just use a regular female spade connector on both the oil sender and the starter solenoid. If not, pick n pull will have a ton for sure. I'm sure toyota used the same connector on many cars in that same generation.
#25
good call on checking other vehicles in the same year range, guess I'll be making 1 more trip out to u-pull it with the oil sensor in hand to track down what I need
toyota trucks get stripped clean pretty quick around here
#26
Im in CO too if you need help or have questions let me know.... I ended up using my 3.4 starter so i should have the connector for 3.0 starter laying around in my garage somewhere as i have a ton of parts laying around lol
ashersullivan88yota
08-19-2015 06:00 PM
