Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
So it begins...94 IFS 3.0 auto to a 3.4 SAS auto
Well, Im gonna give this my best shot. Trying to make my 94 IFS 3.0 auto into a 3.4 SAS auto. Got the engine most of the way out. From what i can gather, the A340H out of the 94 is useless for this conversion? I am attempting to find an entire 3.4 eng/trans/ecu/etc. that will be most easily converted and made cal. smog legal. Is any year more compatable? Ive heard talk of pilot bearing complications which i'd like to avoid. is this applicable in auto's? I heard I also need to locate an older chain driven t/c...any advice is greatly appreciated.
| Sponsored Links |
#2 (permalink) |
the 3.4 tranny wont work since the xfer case output is on the wrong side.
__________________
-Andrew 94 4Runner 3.0 Auto. I got mods |
#3 (permalink) |
your auto will work also
__________________
#4 (permalink) |
Here is the 3.0 thats coming out. Also here is my other 4runner.
#5 (permalink) |
heres my concern
"The 3.0L and 3.4L trucks both use an A340 automatic transmission. Although these transmissions use the same transmission codes, they are very different from each other....The 3.4L requires the use of the ECU from the 3.4L donor vehicle; thus requiring the use of an A340 automatic transmission from the 3.4L donor vehicle." but I hope your right |
#6 (permalink) |
if you don't believe me search a little on here. i've never done the swap, but i've read MANY threads on here. some people with experience would be MT. Goat, elvota. also read about the swaps on Offroad Solutions' website.
__________________
#7 (permalink) |
my quote was from offroad solutions..most threads concerning this refer to R150 5 speed. It bolts directly on. I just cant find anywhere that says the a340h uses identical bellhousing.
__________________
95 4runner 3.0 auto limited 33-12.5-15 intake mod and lift 4.88 stock 94 project 4runner 4.56 stock everything but not for long.. both green:) |
#8 (permalink) |
if i'm not mistaken the 5vze block is identical or very close to the 3vze they should all bolt up to eachother. i just looked on ORS and they sell a swap kit to use your stock auto with the 3.4.
__________________
#9 (permalink) | ||
Quote:
Quote:
Mt.Goat used a taco trans also. Last edited by jasond : 02-02-2008 at 05:53 PM. |
#10 (permalink) |
Get a R150F transmission and a VF1A transfercase out of an '89 - '95 pickup or 4Runner with the 3VZE. These will bolt directly to the 3.4. If you already have the newer R150F and transfer case, sell them and recoup some cash. Good luck.
__________________
Cannondale Rush 3 carbon (my new baby) Surly 1x1 (my D/D) 1973 Schwinn cruiser (my shop bike) |
#11 (permalink) |
http://www.yotatech.com/f160/fyi-5vz...-a340h-128200/
Read this for some good info. It breaks down like this though, you need a T100 ECU and harness to have correct tranny control and no check engine light. The T100 uses the same sensor for the speed sensor in the tranny (reed sensor). ORS sells the adapter harness to make this work and your 4wd to work also. I have one 4runner with a A340H 5VZ. I used the T100 stuff and the 4runner runs great.
__________________
90 4runner built to crawl the malls, spinnin dubs |
#12 (permalink) |
if i was to use the t100 ecu and harness would that mean i would need the 3.4 from t100 also? would it make sense to just find engine/tranny combo if i have someone who wants the 3.0 a340h?
__________________
#13 (permalink) |
The 3.4 auto tranny works the best, its the 3.4 transfer case that has the output on the wrong side. Unlike the A340H the 2 can be seperated easy. Marlin makes an adapter to join the 3.4 auto tranny with a gear driven t-case to make the best of both worlds (that's what ORS uses in their kit).
__________________
Dale "America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens Check out the plan: http://www.pickensplan.com/index.php and http://www.cngnow.com/EN-US/Pages/default.aspx |
#14 (permalink) | |
Quote:
__________________
#15 (permalink) |
deleted
#16 (permalink) |
tranny's out.. boy that was tougher than expected..i hate toyota electrical clips
__________________
#17 (permalink) |
Ok change of plans. I got an 04 4.7L Tundra v-8 4x4 engine, tranny, and transfer case last nite
Also dana 44 ford side high pinion front axle to match the drivers side transfer case output. wish me luck
__________________
#18 (permalink) |
LOL, sorry you can't do that, your thread is in the wrong section.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Flat bottom - auto and IFS | AndyL | 86-95 Trucks & 4Runners | 17 | 12-26-2007 03:22 PM |
| WTB: spring from Factory Auto Hub, '86-'89 IFS | yota4runna | Axles/Suspensions/Tires/Wheels | 2 | 10-21-2007 01:23 PM |
| possible to convert from auto 2WD to auto 4WD? | strive | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 09-29-2006 03:59 PM |
| And so it begins...Auto to Manual transmission swap on 93 3.0 4 runner | Schooler | 86-95 Trucks & 4Runners | 37 | 07-27-2006 05:04 PM |
| Anyone used Capital One Auto Finance or have info on auto financing for me? | AgRunner06 | Off Topic Talk | 9 | 10-09-2005 10:11 PM |
