script to download fsm's from toyota -- anyone want a copy?
Been meaning to post this for a bit, while I had my 48 hours of access I decided it was tracking to long to download and rename all the PDFs individually so I wrote a script that did it for me, not the most user friendly
Rrequires you to read the page source for the manual you are looking for, copy a link and feed it in. Once that's done you set your login details in a config file and run from the command line. Once that's done it will go to work and download all files related to the FSM you are looking for, I used it to snag a complete copy of FSM for 4 years of vehicles related to my swap and associated wiring diagrams.
It will download into folders by section same as how Toyota has things subdivided
Its a python script so if you want a copy to get manuals for you you'll need a copy installed to run it, but you'll also be able to see the source code and know I not trying to steal credentials,or anything
Send me a pm or reply to this post if you'd like me to send a copy, if there is enough interest I'll post it somewhere and add a d/l link to this post.
If you want to go that route, no guarantees you'd find what you need...
I wrote my script and downloaded everything I could need in a couple hours, took just a couple minutes each after that plus the time my computer was working to download
The 90-95 manual is on this page. Just scroll down. I just downloaded the 95 Tacoma manual last week. Once you hit the link it takes about 3 minutes to "find" the document. I recommend you put it on a memory stick. It's a big file.
http://web.archive.org/web/201101022...ttora.com/FSM/
09-04-2015 09:27 AM
