Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Reusable? items from 3.0 to 3.4?
Hi,
I am trying to follow Elvota's 3.4 swap thread. I am planning to buy 3.4 & A340 from '97 4runner and transfer case from '92 4cyl. manual p/u and getting used ECM for '97 3.4 &A340. Item getting from ORS. 1) Wiring kit (should be direct plug in from 3.4, 3.4'sECM to 3.0 right?) 2) Cross over pipes (doesn't come with engine) 3) Header (exh mani doesn't come with engine) 4) power steering lines 5) engine mount 6) battery tray Item use from 3.0? 1) Oil pan & pick up (does it work for IFS with 1.5 BJ spacer, 2"diff drop? or I need T100 ones?) 2) alternator 3) oil pressure sender Not sure 1) dipstick 2) dipstick guide 3) union 4) fuse box 5) EVAP box Please let me know if I am forgetting something here. Thanks
__________________
93 4Runner, 3.0, AT, 2"BL, 1.5 BJ spacers, OME901HD coils, F-open, R-lockright, ISR, 305/70/16 BFG KMs, 33x12.50x15 Swamper TSLs for trail. |
| Sponsored Links |
#2 (permalink) |
Just go to ORS site. There is an entire list there of everything you need and don't need. Print it out and start collecting. good luck. I'm in the middle of this right now.
__________________
1995 Toyota PU SR5 V6, A few mods. |
#3 (permalink) |
Hope this helps.
4) power steering lines - I reused the one off the 3.0 - it worked great. 5) engine mount - just reuse the 3.0 engine mounts Not sure 1) dipstick - Toyota part number 15301-62060 2) dipstick guide - Toyota part number 11452-62060 3) union - Toyota part number 90405-10033 4) fuse box - use the one thats in the 3.0 truck - leave it alone 5) EVAP box - you can use the charcol canistor off the 3.0 - thats what I did - it worked great Good luck!
__________________
Greg - http://www.pureyota.com --- you can't fail if you don't give up. Proud dad of a little girl.. 1. 1997 Tacoma - 3.4 auto - SAS'd - DD 2. 1995 4Runner - SAS'd - FJ62 Front - FZJ80 Rear, 40" Iroks - Beater! 3. 1995 4Runner - 3.4 swapped - Baby mobile/Grocery getter! You can lose a lot of money chasing women, but you'll never lose women chasing money. |
#4 (permalink) |
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#5 (permalink) |
Staff
Items getting from ORS.
1) Wiring kit (will make your life easier... but will make your wallet very light as well. Beleive it or not, you only need to splice 8 to 10 wires to do this swap) 2) Cross over pipes: (I have the 3.4 crossover if you want, then do this: link) 3) Header (see above... but if you want headers the Downey ones seem fine to me) 4) power steering lines (I had one custom made local for around $65 that kept the 3.4 idle up feature... check my thread) 5) engine mount (same as 3.0) 6) battery tray (I fabbed mine... not to hard) Item use from 3.0? 1) Oil pan & pick up (basically, if what you have now on the 3.0 works, it will work with the 3.4) 2) alternator (3.0 will work... check my thread for the minor alt differences) 3) oil pressure sender (use the one from the 3.0) Not sure 1) dipstick (yotaman nailed it) 2) dipstick guide (yotaman nailed it) 3) union (yotaman nailed it) 4) fuse box (yotaman nailed it) 5) EVAP box (yotaman nailed it) If you are on a budget, you don't need to go to ORS for anything. Their products will make you life easier, and I have nothing against them. In fact I have read only good about their design and customer service. I definitely would have gone that way if I needed to. However, the swap itself can be done on your own using writeups here on YT and asking for some help should you get stuck. All that extra you save can be used on other mods or just burned up in gas screaming around with your new 3.4 equipped fireball. ![]()
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - |
#6 (permalink) |
Dipstick and dipstick guide I reused from the 3.0.
I also managed to reuse almost all of the 3.0/3.4 hoses. Some required shortening, but nothing major. If you're going to cut hoses, I suggest using some good quality cutters and not a knife or Olfa cutter. They leave oblong shapes. I reused my power steering hoses. You have to cut a tab off one, but no biggie.
__________________
#7 (permalink) |
Thanks guys,
I read ORS list and other 3.4 swap site, but Elvota's swap seems to be very wise and easy on my budget. Many people told me about wiring, but I have very bad experience with electrical issue in past (not on Toyota) so i feel more comfortable with plug in wiring kit at this time. I am sure I need your experience and advice on the swap in near future.
__________________
#8 (permalink) | |
Staff
Quote:
Be sure to start a thread when you get underway. That's the best way to get strong support from other YT'rs. I know I would have been in deep trouble without everyone that chimed in.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| various items. | Snookster | Misc Stuff (Vehicle Related) | 6 | 01-18-2008 04:43 PM |
| Looking for AMSOIL reusable Airfilter for 3rd Gen | mrmojorisinphan | Items Wanted | 6 | 01-24-2007 09:49 AM |
| Brass washers reusable? | benwahballs | 86-95 Trucks & 4Runners | 8 | 01-08-2007 06:49 AM |
| Reusable Oil Filters | DIHOWARD | General Vehicle Related Topics (Non Year Related) | 3 | 03-25-2006 10:23 PM |
| reusable oil filter | rugerm44 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 05-21-2005 07:16 PM |
