| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
removing pins from the connetors
__________________
Concrete is the cancer of our land,just give me dirt... |
#2 (permalink) |
I had a small screwdriver that I had to grind on all 4 sides until it fit in the hole for the pin connector . oh but it was for a 1uz swap not 3.4 , should work the same though.
__________________
'89 2wd X-tracab,W55,22re,My DD '94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD '88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907, XRC8, Homemade Roof rack.33x10.50,15 KM2 1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake,truetrac front. My swap thread http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/ Last edited by RMA; 10-02-2009 at 07:04 PM. |
#3 (permalink) |
guess it helps to unlock the connector.
__________________
#4 (permalink) |
Man im having the same problem n i got the connector unlocked. didnt have any prob getting pins out until I started the ecu plugs man they are so little.i havent got any yet I just sprayed some contact lube that i use for my crossfaders on my mixer. hopefully it will help.
#5 (permalink) |
Snap On make a small kit to take those pins out of factory plugs.
SnapOn is pricey and hard to locate unless you have a regular truck but I am sure that other tool companies sell the same thing.
__________________
1992 Toyota Pickup Ex-Cab 3.0 V6 4" Pro-Comp lift |
#6 (permalink) |
Yea I finally got all my out took alot of practice and the ecu plugs from my 02 donor suck no matter how great u are. took me about a day to learn to properly unlock and pick them but now I'm a plug removing fool. unpinned the whole 3.0 harness for practice. good stuff guys. I used a bobby pin for most of the smaller connectors eventually my fingers got sore so I went to the 99 cent store and got a small screwdriver set and went to town on em on the bench grinder.
