relay for fuel pump
relay for fuel pump
So finally got to start my truck after swap and I have no power at the fuel pump relay.Got power at fuse box and ground and ign at fuel pump relay,but no constant 12 volts. does the ECU supply 12 volts to the fuel pump relay ?
Check out the 3.4 swap 101 sticky. I made a little write up in which I tried to explain the fuel pump relay and what's happening in there.
Read up and get back with any more specific questions.
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
