Recommendations for Mechanic or Help in Engine Swap - Southern Indiana
Old 04-03-2014, 03:14 PM
jubjub269's Avatar
I have a 2004 tacoma 3.4 V6 manual transmission 4x4. There is about 90,000 miles on it
I noticed some wobble in my crankshaft pulley so I took it to the dealer to check it out
The local toyota dealer said that my crankshaft is damaged and it go in and replace and fix everything it will be $4600
I did some research and it seems just replacing the engine is going to be around the same price if not cheaper so I was wondering if anyone is from around the Southern Indiana area (I live in Evansville). If you know any mechanic that might be able to do a engine swap for cheaper or if someone on here has experience would be willing to help me do it myself that would be great. You would definitely be payed for your help
I am kind of freaking out by how much this is all going to cost and I just want to see if anyone can help out or has suggestions.
Thanks!
Old 04-03-2014, 03:48 PM
JasonYota's Avatar
First mistake is taking it to the dealer.
The cams have nothing to do with a wobbling crank pulley. How bad is it wobbling?
Old 04-03-2014, 03:49 PM
JasonYota's Avatar
Welcome from Alabama
Old 04-03-2014, 04:15 PM
jubjub269's Avatar
Hey thanks for the welcome.
Sorry I meant to type crankshaft instead of camshaft. It was a pretty bad wobble. Apparently the crankshaft pulley was coming off and damaged the crankshaft.
Old 04-03-2014, 04:24 PM
JasonYota's Avatar
That's defiantly a strange issue. Hopefully someone will chime in with more information. Get quite a few options before thinking about replacing the entire engine.
Can a moderator move this thread to the correct section?
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
noahstancik
07-10-2015 11:18 AM
Alex Bessinger
06-28-2015 10:05 AM
merc1100sc
06-26-2015 05:24 PM
Quick Reply: Recommendations for Mechanic or Help in Engine Swap - Southern Indiana
