| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Rayl82's 3.4 swap/3.4 swap. New Pic Post #81
#2 (permalink) |
What took me 11 days sounds like you got done in an afternoon!
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#3 (permalink) |
well, the wiring ain't going as easy as I had hoped. got the body plug for the ecm wired, and has the power, the the tach, vss, 4wd switch, starter, obd II wire, brake light switch, and the wht/red b+ wire. which if I am reading the diagram correctly, the ecm puts out b+ on that wire. But I have no check engine light, no communication with the scanner, and no fire up, it does crank though. It is getting chilly, and dark, and my eyes are fried from looking at these diagrams all day, so I am probably gonna call it a night soon, and start fresh when I get off work tomorrow.
#4 (permalink) |
Are you getting fuel to the engine? And are you getting spark?
I had a much easier problem to solve with mine. First time I tried to start it, nothing. After going through the wiring diagram, realized the starter relay wire was buried and not connected. Fired first time and hasn't let me down since, and I've got 26000 kms (approx 16250 miles) since August.
__________________
#5 (permalink) |
the swap is going well except for the no start thing. the lower radiator hose doesn't fit so we will be using the Napa hoses and the 3.4 therm house the exoust is 23.750" short from connecting the cat and the battery tray needs to be built oh ya the intake mas air flow sensor needs to be incorporated in to the system this is all my job as a cant read a wiring diagram to save my life. hope to here it start tonight...... i leave that in the capable hands of jason4x4.
__________________
89 runner on an 85 runner frame and front axle 3.5" lift suspension 31" A/T tires 1.5"wheel spacers on the front ez locker in the rear crossover high steer and oh ya 3.4L v6 85 Runner buggy in the works... |
#6 (permalink) |
Looks like you guys are getting it done. Bad luck to start this past Sunday. I have never seen it rain solid for so long here in AZ.
Nice job on the crossover re-work. ![]() You'll have to post a writeup on that. A $3 exhaust setup on the 3.4 swap is going to be of interest to many. I'll offer help on the wiring if what you come across rings a bell. Sounds like you have your work cut out for you with the TPS wiring and auto stuff.
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - visit the sticki chronicles
#7 (permalink) |
well, after abotu 10 minutes of looking at it, I didn't have the red/white wire on ign power, and I didn't have power on the blk/red ignitor wire, so we got it fired up, and I am gonna go tweek and tune.
#8 (permalink) |
misfires on 2, 3, and 4, going to get a compression gauge....
#9 (permalink) |
also did the tach mod, here- http://www.trailslesstraveled.com/me...ms/tachmod.jpg , and the tach sits at ~ 1500 rpm with the key on and engine off, and never moves while running.
#10 (permalink) |
#1- 150
#2- 0 #3- 30 #4- 0 #5- 150 #6- didn't check ![]() Guess it's time to put the 3.0 back in...
#11 (permalink) |
Man... that's bad news. Sorry to hear about your luck. Nothing worse than getting so close, then realizing you are farther than you think.
Can you tell if it's valves or rings? I know there is a test to determine, but don't know what it is. I am sure you do though.
__________________
#12 (permalink) |
I rebuilt my motor before putting it in the truck. I would recomend everyone buy a rebuild kit and do it if your going to take the time to do this swap or any for that matter. Might aswell put in a like brand new motor
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more. Might as well start reading this if ya want know more |
#14 (permalink) |
nope, bought it off a local wheeling board, and the guy claimed it had only 19,000 on it. I knew it didn't when I saw it, but it was dropped off with rayl82. I think it actually had 190,000 on it. only thing was the t-belt, wp, and cam/crank seals. I kinda knew something was up when I got it running, it had some massive blow buy and was smoking like a hippie.
#15 (permalink) | |
Quote:
ALSO, looks like we are gonna look for another engine tomorrow, one with a warranty this time. it will be quicker than pulling the heads and sending them out. Last edited by Jason4X4; 01-29-2008 at 08:56 PM. |
#16 (permalink) |
I looked at your linked pic and I am pretty sure that's what I did.
Maybe your tach signal is incorrect? Sounds like the tach is receiving a single steady feed. Is there a way you can hook up a RPM monitor to the feed at the source... just to make sure the signal is doing what it should? I had to run a new wire from my 3.4 to the dash tach wire. I can't remeber why though. Either the harness was missing or to short.
__________________
#17 (permalink) |
the weird thing was that even if I unplugged the body harness the tach still did the same thing.
I'm thinking that something didn't do right with the solder. Last edited by Jason4X4; 01-29-2008 at 09:29 PM. |
#18 (permalink) |
Maybe your solder is covering more points than it should. Seems like the tach is getting a signal from somewhere else. Maybe double check where the tach gauge wire is going.
__________________
#19 (permalink) |
I agree. Make sure you didn't short circuit something with a too large solder joint. Good luck. Mine worked just fine, so it sounds like you've just got a bit of a short.
__________________
#20 (permalink) |
3.4 coming back out
![]() ![]() ![]() so this is the 3rd time since he's owned it that the engine bay was empty. ![]() here's some of the wiring ![]() ![]() 3.0 going back in ![]() we got another 3.4 engine coming, gonna be at my work tomorrow, 81k miles, 6 month warranty.
#21 (permalink) |
That really sux.
![]() Where was the source for the next 3.4? Local? Why put the 3.0 back in if the 3.4 is on the way?
__________________
#22 (permalink) |
it isn't going back in, that was a picture from when we pulled it out. Just trying to make a funny...
The new engine is coming from greenleaf, they just couldn't deliver it today. |
#23 (permalink) |
well, got ahold of the guy we bought the engine from, and he is saying now that it came out of a non running truck that had a bad fuel pump, so it was never checked. he says he didn't misrepresent it, and that it does indeed only have 19k on it. he said he priced it cheap because it came out of a non running truck, woulda been nice to know then. he also said that we coulda checked it before we bought it, but why would we when it only had 19k on it, if he would of said it didn't run, we would of checked it.
#24 (permalink) |
wow man that really sucks. That guy you bought it from sounds pretty shady if you ask me. Is the wiring and ECU from it at least any good? Hopefully you dont have to buy all that again.
__________________
-Brandon 1988 4Runner SR5 4x4 V6 5 Speed Swap (R150F)~SDORI 1.5" BJ Spacers~Downey 26MM TBs~Downey 3" Springs~Downey Shackles~PC ES3000s~PC ES2000 SS~Motive Gear 5.29s~Rear Detroit~Front Lock-Rite~Yakima Load Warrior~33x12.5 Pro Comp M/Ts~Cragar 15x8 Streetlocks~Cobra 18 WXSTII~Marlin Crawler Rear~Addicted Offroad Front Bumper~4X Innovations Sliders~WabFab Bikini Kit~Optima Yellow Top~SS IFS Truss. My 4Runner and Other Stuff |
#25 (permalink) |
I dunno, it was an auto harness and ecu, so we actually got one from a manual so it doesn't set trans codes. but the harness and ecu that we got from the manual is good, since we already had it running.
| Tags |
| 34, control, emission, error, evaporative, fsm, malfunction, po450, pressure, sensor, solder, switching, system, tach, tacoma, toyota, valve, vsv |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| CV Swap ?'s | matthewdmueller | 86-95 Trucks & 4Runners | 3 | 10-26-2007 09:05 AM |
| 1991 4Runner body swap or engine/tranny swap? | 91slowrunner | 86-95 Trucks & 4Runners | 2 | 05-21-2007 10:11 PM |
| 4.3 V8 Swap | 1styota4X4 | 86-95 Trucks & 4Runners | 8 | 07-28-2006 07:35 AM |
| Axle/Gear Swap Help: Will a '94 Auto-V6 4x4 axle swap into my '90 22RE-5spd 4x4? | Justin311 | 86-95 Trucks & 4Runners | 15 | 04-15-2006 12:18 AM |
| 4wd problem/tranny swap/t-case swap wtf | squishy321 | Offroad Tech | 2 | 04-01-2005 11:41 AM |
