Please help demystify wiring for me.
I've read lots of posts on the subject and even the stickies, but I'm at a standstill with wiring. Perhaps I'm making this more complicated than it is.
Here's my scenario...
Donor: 2003 Tacoma w/ R151F
Recipient: 1995 4Runner w/ A340H
The Tacoma's 5VZ engine has a 5-plug harness on it. Three of those plugs go directly into the ECM. Two plugs remain.
Is the entire purpose of the wiring process to take the pins from these two extra engine harness plugs and route them to the two big plugs on the recipient vehicle? In my case this would be IK2 and IK6 (from the donor) to IH1 and IH2 (on the recipient). Is this it? Is that all there is to it? I've documented every pin in a spreadsheet and am having a hard time matching them which leads me to believe I'm doing this wrong. I need some help and I'll even send you my spreadsheet so you can have a look at what I've got. I'm just really confused with this part and the more I read about this process, it doesn't get any clearer for me.
Make an adapter harness that goes. 3.0 body female plugs on body to 3.0 male plugs to 3.4 female body plugs to 3.4 male plugs on engine harness. You will have another plug from your adapter harness that goes to ecu and will have ob2 port tee'd onto that as well.
That was my last one. Working on a 96 runner into 87 runner now.
A lot ofthe time you need to look at not just how the pin is labeled but where it goes to and how it functions.
I bet you will find something useful in this thread
https://www.yotatech.com/forums/f160...-101-a-239002/
jasonty
41
12-23-2018 01:00 PM
