Oregon's Lone Wolf 3.4 swap
#101
For a 97 4Runner 4x4 M/T 5VZ ECU the pins for the MAF are in connector E6 not E7, but are at pins 12, 2, 8 like you mentioned.
Below is a recycled screen shot of a section of that EWD showing the connections to the ECU:
The 3 pins on the bottom of the blue box labeled 'THA', 'VG', and 'E3' are for the MAF. There are 2 circles with a letter in them ('B' or 'F') the upper circle is for M/T ECUs and the lower is for A/T ECUs. Then on the side of the ECU block diagram there's a key that says that connector E6 is abbreviated as 'B' in the diagram. Then the number next to the circle is the pin number.
If you're plugged into the wrong connector, that would certainly cause problems.
#102
Also, how do you like your Marlin short shifter? My next project after the obvious was to replace my bushings and was considering this shifter. Mine is sloppy as all heck. Does it compare to a regular car MT shift?
#103
I assumed you just read/remembered that EWD wrong vs actually wiring up the wrong connectors, but at times like these, any sort of sanity check is good (just to make sure you didn't do something painfully dumb).
I've been happy with the marlin shifter, it took a couple of weeks for the new bushing to break in (though they claim that isn't needed); all the shifts had much more resistance than I expected. Though now, some 2 years and nearly 20,000 miles I'm still super happy with it, everything still shifts really smooth (except going into 1st when cold, but I suspect that isn't the shifter...either pedal bracket or a tired synchro). Only reason I added the short throw shifter vs just a new bushing was to account for the body lift, the stock shifter with boot wouldn't shift into 2nd or reverse.
#104
Yeah, for the money, I suppose I will just do the bushings. I can have those here in a couple of days as I wait for my Cat, 02 sensors, ICM and MAF to be shipped from Michigan now that the budget allows for it. The MAF was toast after all. Waiting on parts has been killing me!!!!! I don't want to put on the PS pump ect. until I can confirm the timing issues I might be having with the cams. Sure would hate to take it all apart again.................SO...........I patiently wait.........again.
#105
Great info. Regarding the ground points. I don't have one in the old battery location as nothing comes off of 97 harness and nothing comes off of the wire loom at the fuse box that I can see. I imagine it would be a ring terminal to a screw. Could this have been an old ground from previous battery location NEG terminal to the sidewall...which would no longer be there? Can you be specific as to where this ground comes from and to where please?
Second, the ground from my alternator to sidewall I didn't add as a part of my 3 big wire upgrades. I put the 8ga wire from the neg to sidewall. Is it necessary that it comes from the ALT? Yes, I would agree this is the better of the two ground points. I did leave the ground from the old ALT harness on the sidewall drivers side with flat large "spade" connector and the ground wire from that to the Manifold bolt on Driver's side. This in addition to the 4ga at the lower engine block seems to work OK. Back of engine to firewall.........CHECK.
The Starter Harness is what has the ground at the battery location. The ground in that harness has the thick wire going down to the frame, and the body ground on the other end that attaches to the side wall next to the battery. Both of these grounds come together to the battery terminal.
Yes the ground off the alternator harness is what I was talking about.
It seems like you got everything in check, just wanted to point that out though. That is why you don't need to ground the ECU box itself. All the grounds coming out of it goes to these spots one way or another and are described in the EWD if you scroll down
Glad to hear the MAF was wired correctly, hope you are having better luck. I have a coolant leak on mine, and have yet to find where it's coming from, and then I was trying to get the idle air valve unstuck, but then I broke the magnet inside lol.
#107
Well, my parts finally came in that include the MAF and ICM. O2 sensors are here and Rock Auto sent the wrong cat back.
I plugged in the MAF and ICM cranked it and got no codes. Not sure why this is happening though.
Still no spark nor start.
The coil connectors show it is getting 12.5 volts.
I checked the crank and cam sensors and coils and they are withing Ohm spec.
The next on the list is to test the IGT signal from the ECU. I pulled the ICU and checked for voltage of the IGF (E5 pin 17) for voltage of 4.5-5.5.................................it was only .705 I think my ECU is TOAST!!!!!!!!!!!!! Seems that every part I got was TRASH! I seem to have the worst luck!
Finding one for my rig is almost impossible!
Anything else I need to check?
#109
I did not make record of which went to where. Sorry . I just wrote on my arm pin x was actually pin x and etc.
The engine harness itself will ground on the intake manifold. Like the 3.0, there should be a ground plug that bolts to the back firewall, located at the top rear of the manifold... Unless it's at a different spot.
#112
My only question is, why am I getting 12.5 volts on the power wires for the coil connectiors? Or does this IGF have to do with the ignitor sending a signal from and back to the ECU? Hell, doesn't matter as it only has .705 volts.
#116
You got 12V at the Coils because they are getting Power right from the Ignition Switch when the Key is On. The other pin of the Coils is a control wire the controls the coils from the Ignitor. The IGF is probably reading low because the resistors, but like you said it was out of specs.
Like the other guy said, make sure BATT has a constant 12V, and make sure +B has 12V only when the Key is on.
There was another guy on here, that actually took apart his ECU and found a scorch mark on the circuit board which was a burnt out component that caused the truck not to run right. I also checked mine too, just because I got it from Ebay. Only a couple screws and the case comes apart, just be very careful if you do, and try not to touch the circuit board.
#117
That makes sense about the coils and the ign switch. I didn't check the BATT for 12v but I guess that would be OK since I am getting 12.5 at the B+ with ign key on. I'll check tomorrow though. After looking at the diagram you are right, must be a resistor. With my luck I would fry it. lol Anyway, I ordered a new used ECU with a 30 day warranty......the project so far is cheaper than a new used truck that would bound to have problems soon after anyway. So far I am into it $3500 with almost new everything.......I can't stop now!
#119
Thanks man!! Well, I had thought I may have aligned the cams with the dots on the sprockets at exhaust at TDC and not compression. Looks like that won't be a future problem as they are lined up on the compression stroke. I'll spend today just putting the rest of the engine together. ECU will be here by Sat I think. I sure would hate to see your coolant leak coming from the H20 pump.
#120
I'll be waiting to see how it goes on Sat.!! Good on you, for taking this project on!! Just remember, be patient, take one step at a time, and you'll get there!
A yr ago I bought my oldest son a $350 car-- to get to work and to teacher him how to maintain a car. I've pulled all the parts he's needed out of the pick n' pull, as it's a waste, buying new parts for a $350 car!! All of the work required I've assisted him, but ensured he's done the lions' share of the work, except for the last electrical problem. He's come a long way.
I'm not sure if it's a great idea to sub an Auto ECU as suggested earlier, more re-pinning would be required!
