One central file location for EWD, FSM, etc.
Getting ready to auto swap to manual. Where can I get this info. Don't mind paying a little. Someone said I need FSM EWD. Wanted to make sure my mechanic has it when I drop the truck off. Someone said Toyota site, is there an exact .com. Or any help will be appreciated. Thanks!
#25
https://techinfo.toyota.com/
Last I checked it was $15 for 48 hour access, then you will need to go through and manually download all of the PDFs you will need. I would suggest you download all of the Repair Manual (FSM) and Electronic Wiring Diagrams (EWD) for your truck. I would also suggest you try to duplicate the directory/folder structure on your PC as Toyota has on their site, it just helps keep things organized on your end and can help you find things a lot faster.
I'm not sure if anything came of this thread but that tech info site is your best bet.
justdifferentials
Just Differentials
09-17-2015 06:14 PM
