| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
OBD II issue
#2 (permalink) |
Is there anybody out there...
it just doesn't make sense, I believe I have everything hooked up right and it isnt working. |
#3 (permalink) |
man Ryan I was just reading something similar to this in another thread but I didnt read it really close but just scanned it. Lemme see if I can find it and i'll post the link. It may turn out that it was something totally different but I'll try.
Obviously the basics, you ohmed out your wire and they are good, ohmed your grounds, etc.
__________________
1992 Toyota Pickup Ex-Cab 3.0 V6 ---> 3.4 swap IN PROGRESS 4" Pro-Comp lift terribly installed by previous owner and a crew of 1st graders it seems 3.0 parts for sale Parting out 97 4Runner 3" body lift for 90-95 Runner $50 |
#4 (permalink) |
LOL....nevermind. Found it but i see YOU posted in that thread.....so i guess that didnt help.
Sorry i couldnt help
__________________
#5 (permalink) |
do you have the key to the on position? the position right be for you start the truck.
__________________
Concrete is the cancer of our land,just give me rocks and dirt.............. |
#6 (permalink) |
haha thanks guys ...yes the key is in the "on" position, I tested the tester out on my cummins and it does work, so IDK what the deal is, yes, i used a multi-meter with the grounds, even ran an extended wire to the driver side intake manifold for the multimeter to get an accurate reading as to where wires are supposed to be grounded. It is baffling me. Any other suggestions?
#7 (permalink) |
Im having the same problem with no results. My reader just says that there is a circuit malfunction on everything so it cant read them....runs like a CHAMP.
I tried a bunch of different grounds and powers, all with the same result.
__________________
94 pickup trail rig/3.0, & 96 tacoma stock. |
#8 (permalink) |
Maybe it's as simple as trying another OBDii tester? IDK ...I've been keeping the vatozone loaner tester on hand in case someone has an idea, haha
#9 (permalink) |
Your wiring is all correct EXCEPT for pin 2. It should go to pin 7 on the OBD II port. Also, the power source should have constant power, not just switched power. This is how I did it and it scans just fine. Good luck.
| Tags |
| circuit, obdii, open, pickup, power, relay, switched, toyota |
