O2 Sensor Questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-18-2009, 07:12 PM   #1 (permalink)
O2 Sensor Questions
I have a truck that I am swapping a 3.4l into. I am running true dual exhaust so there is no Y-Pipe or catalytics converters. Do I need to run two O2 Sensors? and if i do where would be the best place to find them for good price?
LukaDuke15 is offline
Old 10-19-2009, 06:52 PM   #2 (permalink)
The ECM uses one sensor to adjust the fuel trims for both banks. If you only run one sensor, it's input will only come from one bank. I would try to run an X-pipe at least and put the sensor there, but it's got to be pretty close to the heads...I'd say not more than 2 feet downstream or else the readings may be screwed up. For the post cat sensor, you can get one of those simulators that they sell at jegs.
Why not run a single exhaust? This ain't a small block chevy, it's a toyota.
lbhsbz is offline
Old 10-19-2009, 07:52 PM   #3 (permalink)
Thanks for the info. I was going to run the single exhaust but the crossover pipe would not fit because of where the motor is mounted. I also have not seen a truck that runs true dual exhaust so i wanted be unique and see how the truck runs and sounds.
Old 10-20-2009, 05:08 PM   #4 (permalink)
I'll take some pics of my setup tonight...I made the crossover come underneith the bellhousing.
I've also got a set of Downey headers for sale if you don't feel like building stuff.
lbhsbz is offline
Old 10-22-2009, 10:33 AM   #5 (permalink)
Very cool I'll take a look tonight. Another question if I'm not running a catalytic what should i run for an after catalytic o2 sensor because it wont read a difference because there is no cat. So should i run two of the pre-catalytic o2 sensors or should i get an o2 sensor simulator and run an after catalytic sensor?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
