Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Ok, i was going to just put the motor at my shop and work on it, but there is a rush to get it installed soon.
So i am getting the motor out tomorrow and getting it installed by a shop on Wednesday for $400(maybe less) and it should be done by Friday. So the help i need is this... It runs, good, but everyone is getting mad at me because i can't test run it but i am still installing it. So what can i do to insure it will not fail once installed?
__________________
-Phyl 1991 Hilux Surf SSR-G Petrol 3.0L V6 192,000kms l 3.4L V6 264,000kms to be rebuilt then installed! l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Drop in filter l PP 1" Lift Coil Springs l TRD shift knob l Lv. 3 First Aid Kit l White Gauges & Temp Controls l LED conversion l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l TOYOTA TOUR 2008 トヨタ|NEVER QUIT
| Sponsored Links |
#2 (permalink) |
Build a strong surdy stand and wire the motor up and test run it. Not really sure what the real question is here. Did you ever run the new 3.4? Why the rush?
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more. Might as well start reading this if ya want know more |
#3 (permalink) |
I already started it and it runs good. My question is, what should i do before i put it in? if it runs and sounds good, is there anything i should watch out for?
I have never driven a 3.4 before hence all the questions. The rush is that he wants to sell the motor, either that one or the 3.0 i am giving him to one of his friends and i know finding a 3.4L is not easy in Belize so i said i'll do it this week! So as of friday i will be running a 3.4! ![]()
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3.4 swap and a 5 speed swap!!! | yotaman | 3.4 Swaps | 4 | 07-31-2008 01:53 PM |
| 2.7L Swap... What do you think. | bigtrucknwheels | 86-95 Trucks & 4Runners | 12 | 08-01-2007 08:12 PM |
| 1991 4Runner body swap or engine/tranny swap? | 91slowrunner | 86-95 Trucks & 4Runners | 2 | 05-21-2007 10:11 PM |
| Axle/Gear Swap Help: Will a '94 Auto-V6 4x4 axle swap into my '90 22RE-5spd 4x4? | Justin311 | 86-95 Trucks & 4Runners | 15 | 04-15-2006 12:18 AM |
| 4wd problem/tranny swap/t-case swap wtf | squishy321 | Offroad Tech | 2 | 04-01-2005 11:41 AM |
