YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-28-2008, 06:50 PM   #1 (permalink)
neoworm0's Avatar
Mystery wires. Help please.
Any one know what this red and green wire used to be connected to? This is the wire harness that goes to the tranny etc. on a 2000 taco motor. Much appreciated.[IMG][/IMG]
__________________
1995 Toyota PU SR5 V6, A few mods.
neoworm0 is offline
Sponsored Links
To remove this ad, register today!
Old 03-28-2008, 07:06 PM   #2 (permalink)
RobD's Avatar
Auto or manual?
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio
RobD is offline
Old 03-28-2008, 07:11 PM   #3 (permalink)
neoworm0's Avatar
manual
__________________
neoworm0 is offline
Old 03-28-2008, 07:34 PM   #4 (permalink)
RobD's Avatar
I have two guesses, and remember that these are only guesses, but it could be either your back up light switch or your transfer case 4wd engagement switch.
I can't find either colour in my 1997 Tacoma wiring diagrams.
__________________
RobD is offline
Old 03-30-2008, 09:27 AM   #5 (permalink)
jasond's Avatar
On a 4wd, manual t-case (not push button) 2000 taco those two wires are most likely the wires going to the ADD indicator switch. Should be a green wire with a black stripe and a red wire with a white stripe.
If you are hooking up your 4wd light, you should have a plug for the t-case that has a red with white stripe and a white with a black stripe. For your 4wd light to work you will need to connect the green wire with a black stripe and a red wire with a white stripe together as it is in series with the other switch for the t-case.
Before you connect those two wires together, check and make sure that it is the same wire at the switch on the t-case and where your harness is cut (the red wire with the white stripe) with an ohm meter.
jasond is offline
Old 03-30-2008, 08:20 PM   #6 (permalink)
neoworm0's Avatar
Thanks.
I crawled under a 97 today and had a look and it definitely goes to the ADD indicator switch. Thanks for the instructions on hooking it up.
__________________
neoworm0 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Starter mystery joshwindeel 95.5-2004 Tacomas & 96-2002 4Runners 8 12-27-2007 11:48 AM
2 mystery plugs krentigrboi General Electrical & Lighting Related Topics 0 12-12-2007 12:15 PM
Mystery Button KD7NAC_07FJ FJ Cruiser 16 04-28-2007 10:17 PM
22-re mystery vibration 4runnermt 86-95 Trucks & 4Runners 7 02-19-2006 08:06 PM
Yet another Wire mystery Ducky 95.5-2004 Tacomas & 96-2002 4Runners 0 07-25-2003 11:31 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
