Thread Tools | Search this Thread | Display Modes |
#26 (permalink) |
I am not sure about the threads for your fuel fitting.. but i do know that the nipple in the second pic is a drain for the water jacket. that bolt above it is the plug. unless it is in the way of your motor mount, it does not need to be altered.
| Sponsored Links |
#27 (permalink) | |
Quote:
That port is the block coolant drain. I cut the spout off to make room for the engine mount. It will still drain without the little spout sticking out but you're just not able to attach a hose to it for catching the coolant.
__________________
Dale "America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens Check out the plan: http://www.pickensplan.com/index.php and http://www.cngnow.com/EN-US/Pages/default.aspx Last edited by mt_goat : 07-25-2008 at 03:24 PM. |
#28 (permalink) |
Yeah, I have some 5/16 flexible EFI fuel line I want to attach to that pickup line. Just need a fitting for it. And then I have the 1/4" return which I will also run back to the fuel cell.
Thats kinda what I thought port was for. And it is in the way of the motor mount so I guess Ill trim it up. Thanks!
__________________
95 V6 Tacoma - Daily Driver 87 Desert Truck- 5VZFE swapped |
#29 (permalink) |
The threads on that fuel fitting are 14mm X 1.50 thread pitch.
#30 (permalink) |
Put the motor and trans in today to check clearances:
http://img.photobucket.com/albums/v4...ineaug8001.jpg Im using the stock exhaust crossover since I don't have the gas tank or parking brake anymore. But I also had to cut the front diff mount off since it was in the way. As you can see its super close to the torsion bar though. Im going to take it off tomorrow as well as cut the mounts off. I'll be running a long travel kit with coilovers so I don't need them anyways. Plus Ill be able to keep the exhaust higher up. http://img.photobucket.com/albums/v4...ineaug8004.jpg Here is the ORS motor mount: http://img.photobucket.com/albums/v4...ineaug8002.jpg I need to trim about .125" off the passenger mount. Otherwise no issues there. Everything else looks pretty good. The exhaust is real close to the brake lines, I may do new lines at some point. Probably just wrap the down pipe and build a heat shiled temporarily.
__________________
95 V6 Tacoma - Daily Driver 87 Desert Truck- 5VZFE swapped Last edited by G-off : 08-24-2008 at 12:48 PM. |
#31 (permalink) |
Bah...sorry about the blurry pics...
__________________
#32 (permalink) |
Getting there! Engine and trans are finally fully mounted:
![]() ![]() Also picked up a radiator from a 3.0 this week. Probably going to do an electric fan, not sure what one though.
__________________
#33 (permalink) |
And the interior, which is nothing more than a jungle jym of tubes, the ORS stand alone harness, and a steering wheel...
![]() I'll be working on the electrical again today.
__________________
#34 (permalink) |
I like it. I see alot of wires with tape on the end :O
#35 (permalink) |
Yeah, the majority of it is for gauges and lights/switches. There's really not a lot to connect actually. Where to mount all the fuse blocks and relays is my biggest problem right now...
__________________
#36 (permalink) |
Darn close to being able to fire it. Need rad hoses, fan, batt cable, and a few misc things and I should be good.
Couple questions, first, since I am not running a heater right now should I plug the inlet and outlet on the back of the motor? Or loop it together with a piece of hose? And on the PS return hose, can I just run a piece of rubber hose from the pump to the box? I seem to recall them having like a little oil cooler maybe?
__________________
#37 (permalink) | |
Quote:
I can't see that it matters on the heat hose question. If it turns out that you need more cooling you can loop that heater hose through an oil cooler and lower your coolant temps (just like running the heater).
__________________
Dale "America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens Check out the plan: http://www.pickensplan.com/index.php and http://www.cngnow.com/EN-US/Pages/default.aspx Last edited by mt_goat : 09-07-2008 at 04:43 PM. |
#38 (permalink) | |
Quote:
And I was planning on getting a Mojave type heater at some point, maybe I'll just order them both from Summit and be done with it. Thanks!
__________________
#39 (permalink) |
Yeah, as I understand it the 3.4 PS pump is higher pressure than the older models because the rack and pinion steering needs higher pressure. If you hang out with the Taco guys you'll find a lot of them burn up the pumps. I don't know if that transfers over to the gear box steering we have or not, but it can't hurt to have a cooler. Our trucks did have that little hard line cooler. I just happened to have an extra tranny cooler, so I left it in place for the PS.
__________________
Dale "America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens Check out the plan: http://www.pickensplan.com/index.php and http://www.cngnow.com/EN-US/Pages/default.aspx |
#40 (permalink) |
Been slowly tinkering away at it over the last couple weeks.
Got the radiator mounted, 3.0 shroud won't work so I guess I will just get an electric fan. Maybe a Taurus fan. Are their any other decent fans that fit the 3.0 radiators? I also picked up a used Total Chaos Uniball kit so I ripped the old front end off. I'll be running a dual rate 10" Sway-a-way coil over and SAW bumpstops. ![]() Also built a simple exhaust. Im using an o2 simulator so I ditched the cat completely. ![]() Got most of the electronics and gauges mounted, minus the fuse blocks. ![]() About all I need to do now is plumb the EVAP lines. Need to pick up a charcoal canister from the junkyard tomorrow. Then try and fire it, hopefully...
__________________
#41 (permalink) |
Oh yeah, can't remember where these two plugs go, I think the grey goes to the AC compressor? Not sure about the other one...
__________________
#42 (permalink) |
One is the a/c compressor, the other is the signal to the ecu to idle up for the p/s pump pressure. I never did put the p/s pump pressure switch on mine, it runs fine w/o it.
#43 (permalink) |
Thats right! I totally blanked on that. I'll hust leave them as is. Thanks buddy!
__________________
#44 (permalink) |
Well I finally tried to start the truck with no avail. Turns over no problem, the computer was working, but no fuel getting to the motor. Took the line off and it was bone dry, then hooked up a battery directly to the pump which comes on but won't pick up any fuel. I figured fuel delivery would be the biggest problem and so far its living up to that.
Its a E2000 Bronco fuel pump hooked up to my Jaz 32 gallon cell. The pickup tube is on the top of the cell with a cut piece of hose down to the bottom of the cell. The line exits out the cell goes straight down under the cab to a filter than the pump, probably about 3 feet of line to the pump. The old stock 22r mechanical pump did fine with the same cell, but this EFI pump won't do it. I guess its not creating enough of a siphon to get the fuel started...I'll fiddle around with it more this week. What it looks like now at least: ![]() And yes, the igniter came apart so Im getting a new one of those too...
__________________
