FIRST TIME TOY OWNER's 3.4 SWAP THREAD - Page 2 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-16-2008, 10:55 AM   #26 (permalink)
syber_kowboy's Avatar
Send a message via Yahoo to syber_kowboy
Quote:
Originally Posted by RaginYota View Post
how different is the 4runner EWD compared to a pick-up?? I understand that the runner will hav rear wiper..ect..ect...??
I think as far as the body harness go they are the same. I'm not positive but I'm pretty sure. The interior wiring is different because of the rear window, the wiper, the speakers, etc but I'm pretty sure the engine and body plugs are the same from truck to truck. Actually I'm 99% positive because I used body plugs from a 90 auto pickup in my swap and they were exactly the same except it wasn't 4wd.
__________________
'90 4Runner | 3.4 Auto | 1.5" BL | 31" BFG A/T | Smitty built bumper
syber_kowboy is offline
Old 12-16-2008, 10:05 PM   #27 (permalink)
MotoXJunky's Avatar
http://www.chaosfab.com/92300.html
Thats the suspension im putting on the front.
http://www.off-roadweb.com/features/...4x4/index.html
this is my ideal rear suspesion... i wanna keep my rear intact cuz i want to make it available for a blow-up mattress so i can camp
any opinions?
__________________
GO BIG OR GO HOME!!!
MotoXJunky is offline
Old 12-17-2008, 09:39 AM   #28 (permalink)
RobD's Avatar
None of that matters.
All you're doing is wiring up the engine computer. Wipers, etc, are not controlled by the ECU. You're looking at wiring up things like the speed sensor and power. Nothing else.
My engine/ECU came from a 97 Tacoma. No problems with the 91 4Runner.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio
RobD is offline
Old 12-17-2008, 01:39 PM   #29 (permalink)
Does it matter if the 3.4 is out of a 2wd or 4wd? Also I heard the 99 and up have bigger injectors and the MAF is changed? And the engine ECU is totally separate from the tranny controller, so I can use a 3.4(that had an auto behind it) in front of my R150F without any wiring problems, right?
Sorry, /hyjack
__________________
Tyler
1992 White Runner 3VZ/A340
5VZ/R150(in progress)|Inchworm 23spl|MC XD 23spl 4.7's|D60/14B waiting to go in after winter
It's A Jaap Thing
A New High is offline
Old 12-17-2008, 05:14 PM   #30 (permalink)
MotoXJunky's Avatar
I spent half the day trying to get my hub and rotor off and was unsuccessful (ok not half the day but a good part of my evening). im trying to take out my front diff i must be retarded or something
__________________
Old 12-18-2008, 10:31 AM   #31 (permalink)
Quote:
Sorry, /hyjack
You really want to get a 4WD ECM and harness. I think the MAF came in 2000 but I don't know about a separate tranny controller. I think you can use an auto ECM and harness with a manual by tricking it into thinking it's in neutral the whole time but someone wrote something about that causing mapping issues or some such thing. Sorry there are some many "I think" "something" "someone"s, but all the specifics seem to blend together these days.
__________________
Old 12-18-2008, 04:03 PM   #32 (permalink)
MotoXJunky's Avatar
Rob or Kowboy.. i found a 3.4l 4runner engine with ecu and uncut wireharness with all the accessories. it was from an auto for around 1.5K should i jump on it? If it DOESNT have an ecu will it be easy to get one i need?
__________________
Old 12-18-2008, 04:53 PM   #33 (permalink)
scuba's Avatar
Its safe to get the ecu with the same motor from the donor to not f things up...if you cant find one for same year/tranny, you might be down a while looking for said ecu...
But 1500...how many miles...?
__________________
Screw you guys I'm goin to TTORA
scuba is offline
Old 12-18-2008, 04:59 PM   #34 (permalink)
RobD's Avatar
Quote:
If you find the complete engine with ECU and uncut harness, yes, jump on it. Or, better yet, just buy it. That won't be as painful as when you land on the engine.
__________________
RobD is offline
Old 12-18-2008, 05:01 PM   #35 (permalink)
scuba's Avatar
__________________
scuba is offline
Old 12-18-2008, 05:09 PM   #36 (permalink)
Just thought I'd jump in and say that the 99-up injectors are not bigger, their design is just a little bit different and they are just a plastic body. pre-99 injectors and post-99 injectors are completely interchangeable AFAIK. Hard to say if they're better or worse (the plastic bodies can crack if clamped incorrectly), but their flow ratings are basically the same.
Not sure about MAF, but they did start using throttle by wire in 2001 I think, which could change things in the swap.
__________________
Brian
1998 4Runner SR5
mastacox is offline
Old 12-18-2008, 05:18 PM   #37 (permalink)
1500 for a 3.4 with low miles is a pretty good deal but like scuba said, If you don't get the correct ECU with the purchase you'll be searching quite a bit. An auto ECU will go for at least $100. You also have to consider the tranny. I spent about $2k for a motor, tranny, accessories, crossmember, and all the little bits and pieces I needed. You might be able to find a better deal. Just FYI
__________________
Old 12-18-2008, 05:47 PM   #38 (permalink)
MotoXJunky's Avatar
thanks. it has 52,XXX miles on it I emailed dude about the ECU so we'll see what he says
__________________
Old 12-18-2008, 05:54 PM   #39 (permalink)
mt_goat's Avatar
Quote:
No throttle by wire on my 2001, I think it was after 2002, like 03 or mid 02.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 12-18-2008, 06:12 PM   #40 (permalink)
MotoXJunky's Avatar
you guys know anybody that has attempted a 4.7l swap?
__________________
Old 12-18-2008, 07:00 PM   #41 (permalink)
scuba's Avatar
4.7 like outta a toy v8..?
idk.
But I know of a member that put a lexus 1uzfe in his second gen runner...
__________________
scuba is offline
Old 12-18-2008, 08:46 PM   #42 (permalink)
MotoXJunky's Avatar
yeah the new toy V8 yeah i heard of the 1uz swap seems to complicated
__________________
Old 12-19-2008, 10:05 AM   #43 (permalink)
I think the 4.7 is a little big for the engine compartment. The lexus engine fit but he had to lift the truck quite a bit and it still was really tight. I'd stick with the 3.4 man it's got tons of power and really easy to do.
__________________
Old 12-19-2008, 09:13 PM   #44 (permalink)
MotoXJunky's Avatar
so i talked to the dude and he has a 4x2 5vzfe ecu to come with the engine and all the accessories. im ripping out my front driveline so the 4x2 ecu will work good with that, but since its from a different vehicle and engine will it still hook up fine?
__________________
Old 12-21-2008, 07:42 PM   #45 (permalink)
It depends on if the ECU is compatible with the harness and motor. You don't "have" to rip the front end out. Just leave it. But why do the swap if you aren't going to have 4wd? I have a 4x2 auto T100 ECU that'd I'd sell you cheap but if you are using a manual tranny I'd suggest you find a manual ECU. I think they made some changes to the throttle body in mid year 96 so if the motor is older then that and the ecu or harness is newer you are going to have issues.
__________________
Old 12-22-2008, 02:32 PM   #46 (permalink)
MotoXJunky's Avatar
I want to swap so i get more power and an available supercharger. Im not a mudder, crawler type of guy. i am a prerunner/desert type of guy and 4x4 isnt my things hence y i am taking out the front driveline and transfer case. My truck is also auto and imma keep it that way. i plan on buying either a Art carr or winters shifter for it as well.
__________________
Old 12-29-2008, 04:31 PM   #47 (permalink)
MotoXJunky's Avatar
So I got home from san diego for xmas vacation couple days ago.. and my house was robbed. NO JOKE. I came home to an empty house.... well they did leave most of my clothes. The local P.D. came and took fingerprints and the such so hopefully they will find the s. All my tools in the garage are gone, they even tried to take my engine hoist. They didnt find my pink slips tho (guess i hid them too well). n e ways, seems like my project is going to be on hold for a couple months while i replace all my and take care of all this. sorry guys, i will post when i have some new info
__________________
Tags
1990, 34, 4runner, ecm, pigtail, step, swap, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
vwfastg60's 1987 Pickup Build-Up Thread vwfastg60 Build-Up Section 149 11-06-2009 12:38 AM
navyRedneck's 1985 Pickup Build-Up Thread navyredneck Build-Up Section 180 11-30-2008 11:36 AM
Time for a new toy MvCrash Off Topic Talk 26 09-30-2004 06:52 AM
2009 InternetBrands, Inc.
