Finally venturing into my 3.4 swap (dial up warning) - Page 10 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-28-2008, 01:46 AM   #226 (permalink)
breknraj's Avatar
Well, real life and Mother Nature can be a real pain, but Worf is back together and running, again! I did splice in an 8" flex fitting on my exhaust, between the two cats. The only thing I have left to do, now, is to fab up the downpipe support for the bell housing.
I had the usual fun and games bleeding the cooling system, and had to bring the yellow top back up from about 15%, but all is good, again. I also checked the A/C, since I did this job without disconnecting any of the A/C components, and it is still blowing cold!
I'll post pics of the support, once I figure out how I'm going to do it!
__________________
Raj : 1960 Homo Sapien. 192cm, Blonde, Blue. Soon to lose spare tire.
Worf : 1990 SR5 Xtracab 4x4 5 speed, Inca Red Metallic. 3.4 converted, with Taco 5 spoke alloys, 275/65R16 BFG AT K/Os. Soon to add rear e-locker.
breknraj is offline
Old 12-20-2008, 03:51 PM   #227 (permalink)
mt_goat's Avatar
Well crap, mine is cracked now too.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 12-21-2008, 09:58 AM   #228 (permalink)
cadman's Avatar
Ouch . Looks like it's time to make that brace I put on the back burner and modify the stock cross-over to replace the ORS when it does crack.
__________________
"If it's worth doing, it's worth doing right" my father-in-law
1989 4wd Xtra Cab, 3.4L V6
A340F auto, gear drive transfer case, 3" Downey rear leafs, 1.5" BJ spacers, Doetsch Tech shocks front & rear, E-code Hellas
4.88 gears, ARB locked F&R, Toyo Open Country MT 255/85R/16, Procomp 16x8 black steel Krawlers
Badlands Basher front bumper, Warn M8000 winch, All-Pro Off-Road rear Tacoma bumper
Revenge Fabrication Sliders
Alpine CDA 9857
My 3.4 swap
cadman is offline
Old 12-21-2008, 10:33 AM   #229 (permalink)
mt_goat's Avatar
Quote:
What's your plan with the stock x-over?
__________________
~Dale~
mt_goat is offline
Old 12-21-2008, 10:58 AM   #230 (permalink)
cadman's Avatar
Modify it like Jason4x4 did to dump on the driver side, but machine a new collector flange or modify the stock one so it can bolt to a support on the bellhousing like it did on the passenger side. I think the cross-over really needs a mount point at the flange just like the stock config to eliminate or minimize any twisting forces.
__________________
Alpine CDA 9857
My 3.4 swap
cadman is offline
Old 12-21-2008, 11:10 AM   #231 (permalink)
thefallman's Avatar
Send a message via MSN to thefallman
mine seems to be working fine for over a year now no problems and instead of wrapping it is now ceramic coated so i can see immediately if it where to crack. btw just so all of you know if you have a 3 inch body lift all you have to do is drop the transmission crossmember and lower the trans about 4 inches and you can slide the crossover out the drivers side wheel well
__________________
~Brian
GETTING FIXED 89 Ex-Cab 3.4 Conv. T100 Auto Tranny ~Phoenix
94 Ex-Cab 22re 5spd Came with parts truck. Doesnt run yet.
90 4runner 3.0 Auto (Wifes Toy)
92 4runner 3.0 Auto (Currently With Blown Engine) (New 3.4 Swap i think)
thefallman is offline
Old 12-21-2008, 11:13 AM   #232 (permalink)
cadman's Avatar
One big plus with the older cross-over design is it that it is made of two separate pipes and there is no welded junction to fail.
__________________
Alpine CDA 9857
My 3.4 swap
cadman is offline
Old 12-21-2008, 08:06 PM   #233 (permalink)
syber_kowboy's Avatar
Send a message via Yahoo to syber_kowboy
I'm concerned that mine might have cracked due to temperature extremes. I haven't really located the leak but it's definitely on the drivers side. It could be related to a twist/torque issue too. cadman you got yours out by lowering the transmission right? Was that the ORS crossover?
__________________
'90 4Runner | 3.4 Auto | 1.5" BL | 31" BFG A/T | Smitty built bumper
syber_kowboy is offline
Old 12-22-2008, 10:41 AM   #234 (permalink)
cadman's Avatar
Yes, I was able to remove and re-install my ORS cross-over from the driver side by lowering the rear end of the transmission. I just put my tranny jack under the crossmember and unbolted it rather than remove the cross member and move the tranny itself. I have a 1" bl and the spacer I currently have on the cross member lifts the tranny 1" over the stock height, so that probably negates the bl lift somewhat.
__________________
Alpine CDA 9857
My 3.4 swap
cadman is offline
Old 12-29-2008, 11:38 AM   #235 (permalink)
So mine cracked at the collector but I think that was because I ground the weld down a little too thin. I don't know what broke the weld though. It could have been torque or cold snow getting on the hot pipe. Either way it was on the outside area so I was able to weld it without removing it or taking the wheel off. Took about 5 minutes
__________________
Old 12-30-2008, 09:16 AM   #236 (permalink)
thefallman's Avatar
hey syber take a look at my post on the bottom of Dales thread
here http://www.yotatech.com/f160/3-4-swa...5/index29.html
Dale had a crack as well. seems the welded joint is prone to failure. especially when wrapped, with no flex coupling before or near the cat, and no tranny/exhuast mount support.
__________________
~Brian
Tags
38x16, bolt, crossmember, hanksville, shear, strength
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Nearly new '88 4x4 (warning to dial-up viewers!) geoff 86-95 Trucks & 4Runners 51 11-08-2007 03:24 AM
Spider-Man 3 (dial-up warning) humanoid Off Topic Talk 2 07-03-2006 07:06 AM
New Wheels..Pics..Warning to dial up 89macrunner 95.5-2004 Tacomas & 96-2002 4Runners 15 06-02-2005 02:19 PM
Check out these pics of petroglyphs I took (dial up warning) rimpainter.com Off Topic Talk 17 01-03-2005 10:02 AM
Hanna Air (dial-up warning) FirstToy 95.5-2004 Tacomas & 96-2002 4Runners 1 11-24-2004 11:04 AM
2009 InternetBrands, Inc.
