| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Few questions that I cant find answers to about possible swap
__________________
1992 Toyota Pickup Ex-Cab 3.0 V6 4" Pro-Comp lift |
#2 (permalink) | |
Quote:
One of the best sites for information. 1. You will need the complete harness from the 3.4, including the computer, MAF, emissions system, etc. The 3.4 will bolt right up to your 5 speed without any mods. 2. Crossover pipe...I had my made at a local exhaust shop. Used the flanges that came with the engine. The cut the old crossover off and flipped it to the driver's side using new pipes with the old flanges. My advice: keep it as tight to the block as you can and around the bellhousing and make sure there is an expansion joint in it. 3. Personally, I would stay away from any model year that has a throttle-by-wire system. I used a 97 Taco engine and I think that it was a relatively painless swap, compared to the newer engines which have more electronic controls (like anti-theft systems). You ideally want a manual transmission donor so you can use the flywheel and not have to source parts. But I think there are guys who have mated the auto ECU to a manual truck.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#3 (permalink) |
Hi Rob
Thanks for the thoughts. I have Andrew's site bookmarked and read it all earlier. So I understand this correctly, my current computer will be gone and replaced with the Taco one?? It has no other function in the truck other than the motor to where it can be tossed, or will I have two ECU's in there if I do the swap?
__________________
#4 (permalink) |
Before you go too far, contact your local BAR referee and find out what will he will pass or fail you for, especially the exhaust system from the crossover pipe back. This will save you some grief.
__________________
"If it's worth doing, it's worth doing right" my father-in-law 1989 4wd Xtra Cab, 3.4L V6 A340F auto, gear drive transfer case, 3" Downey rear leafs, 1.5" BJ spacers, Doetsch Tech shocks front & rear, E-code Hellas 4.88 gears, ARB locked F&R, Toyo Open Country MT 255/85R/16, Procomp 16x8 black steel Krawlers Badlands Basher front bumper, Warn M8000 winch, All-Pro Off-Road rear Tacoma bumper Revenge Fabrication Sliders Alpine CDA 9857 My 3.4 swap |
#5 (permalink) |
You toss the 3.0 ECU and run the 3.4 ECU instead.
Cadman brings up a very good point. Since you are in California, you will need to make sure that the entire emissions system is kept and run as though it was still in the Tacoma. He had problems passing because he routed the exhaust down the driver's side instead of the passenger side, like it was in the Taco. It makes no difference in the emissions, obviously, but could make all the difference in you passing your next smog. Check his install (one of the cleanest I've seen) for details. I'm not sure of the link.
__________________
#6 (permalink) |
thanks for the tip. Just spent an hour reading Cadman's whole thread. I'll go talk to a referee before starting anything. If its an issue, I'll have to install the exhaust that "falls out" like he did!!
__________________
#7 (permalink) |
In my search for a donor I am amazed at how dang expensive these older Tacomas are.....even if I can find one with a V6 in it.
Anyway, I have read so much the past few days(just about every post on here in its entirety) it seems that the problem of place a auto trans motor and ecm into a 5 speed truck is solved but cant remember where I found it. Anyway, if I find a donor with auto am i going to trip codes by having it in a 5speed truck. This would open me up to looking for a 40runner rather than just the Tacomas obviously. Thanks!!
__________________
#8 (permalink) |
__________________
#9 (permalink) |
hey thanks Rob.
I had seen one of those but the other popped up since my last search. Will call later today and get details.
__________________
#10 (permalink) |
Make sure you get everything. I got mine complete, including A/C compressor, power steering pump, fan, intake, exhaust, uncut wiring harness, flywheel and clutch, oil pan, computer...everything.
If you get just the engine, it's going to be a lot harder piecing everything together. Not impossible, but a scavenger hunt, to be sure.
__________________
#11 (permalink) |
Hi all Ok so here is the deal with that motor.
Guy has a T100 with 160,000 miles on it. that is the motor that is for sale. He bought a totalled Tacoma with 70,000 miles on it and is swapping the motor from the Tacoma to the T-100 and then selling the T-100 motor. I can buy the T-100 motor(160,000) which is a 5speed and the entire, Tacoma (2x4 auto)less the motor, for $1000. I will get exhaust, PS, AC all the knick knacks off the Tacoma as he says that they are all there. Truck is pretty trashed. No interior, etc. so recouping money from parting out would be minimal. T-100 is 5speed 4x4 and Tacoma is 2x4 and auto I then run into the issue of taking 2x4 auto computer and dealing with that into my 92 4x4. Opinions????
__________________
#12 (permalink) |
Ok Cadman
Finally got a call back from the referee and he didn't seem to know. Referred me to a state guy that didn't know either. Told me to file a formal complaint to Bureau of Automotive Repair and they would investigate it and call me back. So my question is for you. Before your old exhaust fell off and was lost. Would it have been possible for you to route your exhaust on the passenger side without a body lift? I'd rather not lift the body but I will if I have to.
__________________
#13 (permalink) | |
Quote:
I'm not a fan of bodylifts myself, but in this case I'm glad I installed my 1" lift. The hood clears the engine without any cutting, installing the starter is an easy 5 minute job (slips right through the wheel well) & I can R&R the crossover pipe with the engine in place.
__________________
