| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#51 (permalink) | ||||||
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more. Might as well start reading this if ya want know more |
#52 (permalink) |
I just used the 3.4 alt.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#53 (permalink) | |
Quote:
That's a good point. I'll remove it before install. It's just there loosely to make sure if fit, so shouldn't be a problem. Thanks for the tip.
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - visit the sticki chronicles
#54 (permalink) | |
Quote:
__________________
#55 (permalink) |
Fuel Line Redirect
Got a few things done today. Pretty much has been raining since noon... so couldn't get to the truck itself. Shouldn't' complain, I can remember Breknraj completing this swap under a tarp in 12 inches of snow.
Started moving around the fuel lines from the PS to the DS. Just like Fallman had recommended, you can rotate the 3.4 supply line pretty easily. Just loosen the banjo bolt at the end of the fuel rail and give it a twirl. Something like this: ![]() Of course, I don't have it in the truck yet... but it seems plenty long enough to reach the factory 3.0 hardline and the ends are compatible. No adapters or couplers should be required. Also re-routed the return line. Original position (rubber hose curved in foreground): ![]() This took slightly more work, but was pretty straightforward. Just rotate the rubber U-bend and cut off one of the hardline brackets. The remaining bracket bolts perfectly to an existing hole in the intake. The bracket and hardline are pretty easy to tweak and get things where you need them. End result: ![]() You can now see the return heading to the PS and ready to be connected. I'll just tie this one into the existing 3.0 return line as well with some extra fuel grade hose.
__________________
#56 (permalink) |
Diagnosis Box Repair
My 3.4 donor had been hit pretty hard on the DS front fender, and that took the EVAP box as well as a few other items from that side of the engine. While I have found a new EVAP box and related components at another salvage yard, I had a crushed 3.4 diagnosis box to deal with.
My plan is to add a OBDII port inside, but figured this box will come in handy for timing and such... at least it was necessary on the 3.0. Question: I have heard that an OBDII port is an OBDII port. Any truth to that? I need to find one at the salvage yard and thought I'd just look for one in any vehicle. Anyone know what years and up I should start looking? '96 and up maybe? So, I took a closer look at the difference between the 3.0 box and the 3.4 box. Turns out they are pretty similiar, as most items involved with this swap. The layout of the 3.4 box: ![]() The layout of the 3.0 box: ![]() As one can sort of make out from the pics, the connections and basic layout between the two are almost identical. The 3.4 has a few more options, but very close. I transfered the B+, TE1, E1 and IG leads from the 3.4 harness to my almost undamaged 3.0 diagnosis box. I had a few 3.4 wires left, but didn't bother connecting them. I left them hanging instead and can join them later if I find it necessary to do so. At least I have a usable box for now, with the connections accessible for timing and other procedures in the future. Plus the lid diagram is still correct :![]() Hopefully the rain will die down a bit and I can start working on relocating the battery. I plan to build my own tray, so we'll see how that works out.
__________________
#57 (permalink) |
Ya i bought my headers from performance products and didnt get the right year without the egr. i did notice after the fact that they mention what come with and without it. I should have just called them yet performance products had a good deal on them at the time.
__________________
#58 (permalink) |
the obdII is a plug you can buy. you can take it from any model but youll want the pins for it. I bought mine from a site i dont remember and it came with the female and 10 pins. it only takes 4 wires to connect and make work
__________________
#59 (permalink) |
Thanks. I look around. Hadn't thought about going new for that part. I do know the connections I need from the 3.4 electronics, so I'll just have to put all that together now.
__________________
#60 (permalink) |
a new one plus shipping cost me $11 so not too bad. i did have troubles with shipping cause of usps but that wasnt the companies fault. the site was www.carplugs.com they sell the plug and pins for the OBDII. as for the schematics which youll need for the exact year make model check out https://techinfo.toyota.com/ youll have to pay by day or month hell even year but in one day you can get tons and tons of info for everything imaginable for you and this swap. save and print it all
__________________
#61 (permalink) | |
Quote:
I signed on to the TIS website before I started this swap. You are right, a very important site to gain lot's of information. Has really helped me figure out the wiring and related.
__________________
#62 (permalink) |
Can't believe I've missed this thread. Good to see the swap is well underway, Steve. If you need a hand stuffing the new engine in, give me a shout! I love that stuff. And of course I have a stock 97 3.4 for reference anytime if needed.
So... seeing the status, guess it would be tough to lead Frank and me on 404 tomorrow, huh?
__________________
Jon 97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets |
#63 (permalink) | |
Quote:
![]() With all this rain, the area should be really cool. I am looking forward to getting this project done and back out on the trails again ASAP.
__________________
#64 (permalink) | |
Quote:
Its funny your having to work in the rain cause im in seattle and deal with that, cold, and now a bit of snow haha good times. Ive almost got mine up and running after my swap seems that my MAF and intake temp sensor are done. This is the only code im throwing so hopefully this week ill be done with mine and ready to roll. Btw i also have to build my tranny tunnel after my flatbelly and add some new seats and i should be good to go this all is gonna be done in the rain or snow aswell so i feel your pain
__________________
#65 (permalink) |
Working on finalizing the wiring today and came across a question... maybe someone will know the answer.
From the 3.4 ECM, I have a wire that wants to go to the "malfunction indicator lamp [comb. meter]". Now, I also have a wire from the 3.4 ECM that wants to go to "bulb check relay [comb. meter]" They are two completely different wires at two completely different pins on the 3.4 ECM plug. The catch is I can only find a lead for the "check engine" bulb at the comb meter coming from the 3.0. I cannot locate a relay lead. My guess is that the 3.0 might not have a check bulb relay... only the bulb itself. My plan is to connect the 3.4 lead looking for the "indicator lamp" to the "check engine" lead from the 3.0. I'd just leave the 3.4 lead looking for the bulb check relay disconnected. Thoughts, ideas, comments....
__________________
#66 (permalink) |
Few more things checked off the list today.
Got the harness fully reassembled. Major chore. ![]() This will be news to no one... but make sure you get a unmolested harness if at all possible. That said, I have learned a heck of a lot about this 3.4 and it's wiring, so maybe not all bad. Much better: ![]() I'll post up some tips of what I did connection wise when I know what works and what doesn't. So far, I haven't been forced to make any guesses in regards to wiring connections or how the 3.4 ECM will tie into the 4Runner, so am as confident as possible that things are going well. It's amazing how similiar the model years are. 85% of the wires are the same color from each motor. I also have a good handle on wiring diagrams now. Before all this, they just looked like jumbled modern art to me. ![]() My motor mounts should be in Tuesday so I can drop the 3.4 in place and starting doing final routing and connections. Slowly moving forward...
__________________
#67 (permalink) |
Battery Tray
Fabbed up a battery tray for the DS fender. Turned out pretty good. To be honest, my battery wasn't ever really that secured to the factory position, so this new mount is a vast improvement.
![]() Completed tray: ![]() Sweet hold down (notice the lightening holes )![]() Tray installed: ![]() Battery installed: ![]() Final fit was excellent, tucked in just fine behind the radiator overflow. Now I just have to build the starter harness.
__________________
#68 (permalink) |
Nice work on that battery tray!
__________________
1995 Toyota PU SR5. 2000 3.4l V6 and a few other mods. my album: http://www.yotatech.com/album.php?albumid=101 my SAS: http://picasaweb.google.com/areinhol...eat=directlink www.overlandcanada.ca www.alltracwagon.net |
#69 (permalink) |
Steve, that is coming along nicely. Good work on the battery tray and retro fitting your old alternator as well. Get it done!
The trails are waiting. This latest storm flooded most of the wash trails and cleaned them out. It looked as if nobody had driven them in a long time, it was great.
__________________
'86 Toy Flatbed with a few modifications |
#70 (permalink) |
Steve...this question might be a bit late but do you need the engine sections from the FSM?
__________________
Lance 2001 4Runner Limited 4X4 -- 315/75R16 MT/Rs | MT Classic IIs | Dual ARBs/4.88s | (F) 5125/Tundra Coils (R) 5125/LC Coils | 4Crawler 1.5" BL | Aisin Manual Hubs | Slee Sliders | Sonoran Steel Rear Bumper | TJM T-15 w/ Warn M8000 2004 Land Cruiser -- OME Medium Lift | Nitto Terra Grapplers |
#71 (permalink) |
Im pretty sure he used techinfo.toyota.com to get what he needed as far a FSM stuff
__________________
#72 (permalink) | |
Quote:
Also, I have a few local guys who have been willing to look under their hoods to help with pieces of the puzzle.
__________________
#73 (permalink) |
I figured you had it but wanted to make the offer. I downloaded all the '01 4Runner and '99 UZJ100 manuals from the TIS site myself.
__________________
#74 (permalink) |
Another helpful site ive used is www.deserted1.com/FSM/ its helped me quite a bit with diagnostics and a few other misc things. the only problem is its for an 03 taco
and not the 96 t100 stuff ive been working with. still its a pretty good site. I wish my buddy kept his 4runner and i knew people with 3.4's lol oh well
__________________
#75 (permalink) | |
Quote:
my harness is missing the dash side of the plug and thats what i'm waiting on now thanks
__________________
89 runner on an 85 runner frame and front axle 3.5" lift suspension 31" A/T tires 1.5"wheel spacers on the front ez locker in the rear crossover high steer and oh ya 3.4L v6 85 Runner buggy in the works... |
| Tags |
| 1991, 34, 34l, 4runner, 5vzfe, 95, belt, compatibility, diy, guide, speed, spline, swap, timing, toyota, ts26271, writeup |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Elvota's '90 SAS 4Runner | Elvota | 4Runners-2nd gen | 3 | 12-28-2007 03:39 PM |
| 1991 4Runner body swap or engine/tranny swap? | 91slowrunner | 86-95 Trucks & 4Runners | 2 | 05-21-2007 10:11 PM |
| 3.0 to 3.4 swap?s | 91truck | 86-95 Trucks & 4Runners | 5 | 03-26-2007 08:41 PM |
| Axle/Gear Swap Help: Will a '94 Auto-V6 4x4 axle swap into my '90 22RE-5spd 4x4? | Justin311 | 86-95 Trucks & 4Runners | 15 | 04-15-2006 12:18 AM |
| 4wd problem/tranny swap/t-case swap wtf | squishy321 | Offroad Tech | 2 | 04-01-2005 11:41 AM |
