AW4 to a 3.4?
Old 10-28-2014, 04:36 PM
joe mcg's Avatar
AW4 to a 3.4?
Has anyone mated a Jeep AW4 tranny to a 3.4. Is it doable and how? Thanks
Old 10-30-2014, 12:04 AM
BigBluePile's Avatar
Why...?
Old 10-30-2014, 12:09 AM
wyoming9's Avatar
Red face
With enough of a budget anything can be done !!
Why do it though because mating that trans at a guess will cost a good bit.
Then there is the use of that forbidden word as well.
Old 10-30-2014, 05:45 AM
blake.nemitz's Avatar
yes and its easier than you think. the aw4 and a340 are the same trans. swap bellhousing, oil pump, torque convertor, and valve body from an a340 to the aw4 and your good to go. google search aw4 a340 swapability.
you might not have to go that far if the valve bodies are close enough just the bell and tq convertor. yota motors in a jeep would be cool or if your looking for an atlas case to bolt up this would be the best option
Old 10-30-2014, 05:47 AM
there is a guy who put a twin turbo 2jz in a cherokee and thats what he did to build a 4wd trans out of the toyota a340e 2wd tranny that came with the swap.
what are your goals? I can help more if you can be more specific.
Old 10-30-2014, 12:48 PM
joe mcg's Avatar
Thanks! Building a buggy and want to use the 3.4 for a motor and need the AW4 to use an Atlas. Any info would be great. Do I need to swap the input shaft?
Old 11-01-2014, 03:50 PM
dntsdad's Avatar
It's a fairly simple swap that I looked into a long time ago but I can't remember all the details now.
Search on pirate4x4 and you find everything you need.
Steven.m.paulk
06-07-2020 10:45 AM
primordialbeast117
12-19-2015 12:23 PM
White Stripe
10-06-2015 10:47 AM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
83
18
09-21-2015 06:15 PM
Quick Reply: AW4 to a 3.4?
