automatic transmission
hey all ...
installing a 1995 T100 3.4L auto , into a /94 3.0L auto . truck .
have a question .
the /94 has 4 shift solenoids and theT100 only has 3 . not quite sure how to wire this ? anyone have any ideas ?
/94 EWD ATM tranny
95 T100 EWD tranny
have a question .
/94 EWD ATM tranny
95 T100 EWD tranny
Yes, if you go to the system outline for the ECT EWD it offers an explanation. I rig up a relay to send power to the solenoid when L4 is selected. Keep in mind to explain to customer that he needs to follow the L4 shifting instructions as you bypass the ecu deciding when its safe to shift into L4.
No worries, I've done a few of these and try to help others when I can.
Also depending what it goes into, if it was fuel injected then there is a speed signal from cluster that goes to ecu. You match that up as the 3.4 has the same function. Then you either keep the cable speed sensor if it was cable, or if your rig has electric speedo you wire it back up.
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
12-27-2016 01:58 PM
BeMiceElf
10-10-2015 09:40 PM
kelly1450
09-02-2015 12:29 PM
Hugh_Mann
08-31-2015 04:02 AM
