| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Anybody NOT relocate the battery?
#2 (permalink) |
You'd have to do some sort of custom intake, because there really isn't enough room to fit the stock airbox anywhere else.
I'm thinking about removing the intake silencer and all that and seeing if I can find an airbox that will fit behind the fuse block, above the wheel well, and route the intake out through the side of fender.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#3 (permalink) |
Its really not that hard to move the battery, i would just do that.
__________________
Mike 1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, Locked, 5.29's, 39.5" iroks on Beadlocks, Armor'd Longfields, Duals coming soon: My build thread http://www.yotatech.com/f152/904_run...thread-158746/ http://www.treadlightly.org/ http://www.pirate4x4.com/tech/billav...ery/index.html |
#4 (permalink) |
Well to move the battery I need to do some welding. I don't want to pay for that and I dont have a welder.
I dont have a complete intake, just the inlet hose so I thinking about finding a universal flex hose and a compact cone filter and calling it a day. I dont care if its a hot air intake, I just need a filter on the end of the maf.
#5 (permalink) |
I did mine a little different added a battery and intake with a aftermarket K&N Style air filter but no stock air box
![]() I used a already existing hole in the fender and a hook mount style battery hold down with the red top ultima battery on the drivers side and had to turn the over flow 180 degree's to get the Ultima laid on it's side to fit.I left the stock battery where it is from the factory so now the second battery powers all my extras and the blue thing on top in the picture is a battery isolator from the alternator to charge both battery's and it work very well.
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. |
#6 (permalink) |
You cant really even do a battery-intake swap on a 3vze anyways. The intake plenum is facing the driver's side, which the battery is NOT on
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler '88 4runner|22re|5spd|206K miles|Sold '93 single cab|22re|5spd|150K miles|Sold| Pro IFS Last edited by toyota4x4907; 10-21-2009 at 09:44 PM. |
#7 (permalink) |
UK did the 3.4 swap and wants to keep the battery on the stock 3.0 side.
__________________
"If it's worth doing, it's worth doing right" my father-in-law 1989 4wd Xtra Cab, 3.4L V6 A340F auto, gear drive transfer case, 3" Downey rear leafs, 1.5" BJ spacers, Doetsch Tech shocks front & rear, E-code Hellas 4.88 gears, ARB locked F&R, Toyo Open Country MT 255/85R/16, Procomp 16x8 black steel Krawlers Badlands Basher front bumper, Warn M8000 winch, All-Pro Off-Road rear Tacoma bumper Revenge Fabrication Sliders Alpine CDA 9857 My 3.4 swap |
#8 (permalink) | |
Quote:
__________________
-+-( 1993 Toyota XtraCab Pickup )-( SR5 3VZ-E 5spd 4x4 )-( 32x11.50A/T's HellaH4's )-( 360,000+km ) |
#9 (permalink) |
There is no welding of the motor mounts to swap the 3.0 with the 3.4 engine, you reuse the 3.0 brackets & isolators.
__________________
#10 (permalink) |
im sure you could make a short ram intake with a filter and make a spot for the maf sensor
#11 (permalink) |
I didn't do any welding when i did my swap..
I have an optima, so i bolted the red tray down to teh fender and strapped it down.. it is SOLID..
__________________
#12 (permalink) |
I didn't weld my tray in either. I bolted it down. Still solid after 6 months of wheeling.
__________________
1995 Toyota PU SR5. 2000 3.4l V6 and a few other mods. my album: http://www.yotatech.com/album.php?albumid=101 my SAS: http://picasaweb.google.com/areinhol...eat=directlink www.overlandcanada.ca www.alltracwagon.net |
#13 (permalink) |
My tray and holder are also bolted in, and rock solid. Personally, I would suggest NOT welding in the tray. If you run a non-sealed battery you'll want to be able to remove the tray to neutralize any leaking battery acid that makes it's way underneath it.
__________________
