| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
not sure on some of your other questions but I did see a few pair of Downeys on the Pirate4x4 classifieds if its not too late.
Good luck and make a thread noting your work/problems.successes/ideas basically everything for those of us going to take this on in the future. Best of luck
__________________
1992 Toyota Pickup Ex-Cab 3.0 V6 4" Pro-Comp lift |
#3 (permalink) |
Other things to be aware of...
Oil Pressure sender swap oil pickup tube and pan swap. engine mount brackets wiring battery tray moved to drivers side thats about it. Good Luck and keep us posted
__________________
86 Pickup 4x2, Manual (Sold) 87 Extra Cab Pickup 4x4, Manual (Sold) 93 4Runner 4x4, Manual, 3.4 Swap In progress 90 4Runner 4x4, Manual, Blown 3.0 (Stripping out for parts then to become a trail rig/camping/fun truck) 94 Lexus SC400, 1UZ, magnaflow exhaust, after market headlights, bought for parts for the swap into the 90 4Runner |
#4 (permalink) |
Thanks for the help guys.
I have a bit of a dilemma. I'm trying to decide if I should wait to source an entire T100 (or at least a front clip) or should I source the parts individually. Depending on how much I can find a T100 for, I am thinking it will be cheaper and easier in the long run to source the full truck and then swap the parts. This way I will have all of the other parts that I may need, all from the same donor. I'm also working on my graduate degree so time will also be a factor. |
#5 (permalink) |
To save you time and money go with the entire truck if you can. Cause you need sensors and connectors under the dash, everything off of the firewalls. Makes it a lot easier. Then the differences between years from 3.4s. It's just a better idea to go with as much as you can. My opinion. Are you stuck on a T-100 3.4? Cause you can get them from Tacomas and 4Runners from years 95.5- 2004.
__________________
#6 (permalink) |
I was hoping to stick with the T100 only because it will control the A340H or I may swap in the T100 transmission. I'm leaning more towards keeping the A340H however, this way I don't have to worry about crossmembers, transfercase adapters, driveline lengths, or interior modifications.
Basically I'm trying to do this as cleanly as possible. I'm sure I could use a mix of parts from the tacoma's and Runners as well. Mostly I will need a T100 Auto Ecu and engine harness. |
#7 (permalink) |
If you are going to mix and match parts be sure to get the engine and harness and computer all from the same donor vehicle. Everything you can mix and match basically.
__________________
