| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
3.4 swappers who did there own wiring
__________________
Concrete is the cancer of our land,just give me dirt... Last edited by BIG RON; 10-01-2009 at 03:46 PM. |
#2 (permalink) |
Unless the connectors are missing (cut off, ripped off), the 3.4 engine harness has the connectors for the O2 sensors and VSV, so that portion of the wiring is plug & play. Is your 4Runner 2wd or 4wd? If it is 4wd you need the big square evap box or the ref will fail you. The 2wd Tacos still used the round 3.0 style evap cannister, up to what year I don't know.
Before you do the tranny conversion, go talk to the ref you'll be going to about that. My swap was straight forward because it was auto to auto, but there is the possibilty a conversion may be a no no. My BAR sticker has the transmission type listed on it, so just check to be sure.
__________________
"If it's worth doing, it's worth doing right" my father-in-law 1989 4wd Xtra Cab, 3.4L V6 A340F auto, gear drive transfer case, 3" Downey rear leafs, 1.5" BJ spacers, Doetsch Tech shocks front & rear, E-code Hellas 4.88 gears, ARB locked F&R, Toyo Open Country MT 255/85R/16, Procomp 16x8 black steel Krawlers Badlands Basher front bumper, Warn M8000 winch, All-Pro Off-Road rear Tacoma bumper Revenge Fabrication Sliders Alpine CDA 9857 My 3.4 swap |
#3 (permalink) |
I pulled the harness and ecu my self, the one connector for the valve assy. vacuum. sw. that is attached to the side of the evap can, was wired into the body harness, not the engine harness.
__________________
Concrete is the cancer of our land,just give me dirt... |
#4 (permalink) |
Its been a while since I finished my swap and tossed the 3.0 harness, but all of the emissions related sensors (O2, VSV, knock, etc..) connect to the engine harness, 3.4 & 3.0. Once I pulled the 3.0 harness from the truck I had no extra connectors in the engine compartment, except for the oddball one near the alternator wires that no one seems to know what it is for.
If you have something different, post a picture so we can see what you are talking about, and give some more specifics, like what harness and devices your are hooking up (3.4, 3.0). It sounds like you are trying to connect 3.0 VSV and O2 sensors to the 3.4 harness.
__________________
#5 (permalink) |
the o2 sensors i figured out, I don't no what I was thinking. I'm not trying to connect any of the emission stuff from the 3.0. what I'm talking about is the valve assy. vacuum sw. connector and wiring for the 3.4, it was part of the body harness not the engine harness, so I cut it off so I would have it. the other two connectors that plug into the vapor pressure sensor, that bolts to the firewall and the other vapor pressure sensor that is on the evap canister are part of the engine harness.
__________________
#6 (permalink) |
Are you talking about the vacuum related components for the ADD?
__________________
