Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
3.4 swapped running rough
I mentioned this in my other thread - but since I have got no replies I thought I would post it up on its own- the swap is complete as of last week it fired up but runs really rough. I don't have an OBD connector yet so I can't pull codes. If the mass air flow meter is disconnected the motor starts and runs much smoother? I checked the mass air flow as per the FSM and it checks out. I am in the proccess of checking othe input signals to the ECM but I don't really know where to start. Anyone have any advice? What are the basic signals teh computer checks to run? I would assume Cam/crank sensors for timing, MAF for air volume/density, throttle position and........? I was really hoping this would have fired up and ran smooth, not my luck I guess.
__________________
1992 4Runner -33x12.5 BFG AT's - 3.4 Swapped |
| Sponsored Links |
#2 (permalink) |
Do you have the correct airflow meter? The wrong year airflow meter will cause the condition you describe. Airflow meters need to be 96-98 or 99 and newer. Make sure they match the year of the ECU.
__________________
90 4runner built to crawl the malls, spinnin dubs |
#3 (permalink) |
I would also check your grounds, including the ground for your igniter. Make sure it is good and clean under the bolt that you presumably attached to the passenger side fender.
__________________
1991 4Runner, 3.4 5VZFE swap, OME shocks/springs, 33" BFG All Terrain T/A KOs, Pioneer head unit, Infinity speakers, XM Satellite radio |
#4 (permalink) |
Thanks for the replies - Everything came from the same truck -'99 Tacoma 5spd- I have checked grounds. I even ran a separate ground to the ignitor from the block as recommended in many threads here. I don't think there is much more I can do without hooking up the OBD port and pulling codes.... so close and yet so far....
__________________
#5 (permalink) |
Oh, give the vacuum lines a good checking, too. Spray them with carb cleaner (gives a temporary seal) and see if the idle smooths out.
Mine ran a bit odd until I found a split hose.
__________________
#6 (permalink) |
Now I am really needin' help... got my OBD port wired up and borrowed a reader - code read error- checked out the pins on the OBD port - I have 11volts at the data link wire???? It should be 'pulse generation'.- i would assume this means fluctuating betwen 0- 12v- mine is a constant 11v. AS mentioned in the earlier post- if I unplug the MAF it smoothes out.
Anyone? Pretty please. ![]()
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rough Running and Rough Idle | b18vteceg | 86-95 Trucks & 4Runners | 12 | 05-09-2007 02:07 PM |
| Rough idle on swapped 22re... Any ideas? | NotMatt | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 06-10-2005 07:13 PM |
| Running Rough | AndroT100 | 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 | 13 | 07-16-2004 01:29 PM |
| Running Rough | AndroT100 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 07-05-2004 08:14 PM |
| 3.0 running rough | vmaxjohn | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 06-25-2003 06:57 AM |
