| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#701 (permalink) | |||||
__________________
1995 4runner 5spd 4wd 3.4 swap |
#702 (permalink) |
Just a little update. I finally got in a long trip with this truck, a 2000 mile tour of Colorado. It did great performance wise, cruising up mountain passes with ease, it was hard to keep it under the speed limit actually. The supercharger makes altitude changes a breese and it was hard to get the grin off my face most of the time (except when filling up at the gas stations). I actually got some fairly good MPGs, around 18 mpg in the mountains. There is much less wind resistance in the higher elevations so the MPGs goes up. Best mpg was 18.6, worst was 11.19 (mostly offroad wheeling)
One problem was a broken supercharger belt somewhere near the Colorado/Kansas border. The belt only had about 3000 miles on it, I'd heard they were prone to failure so I had a spare one with me to put on. Changing it requires first removing the PS belt and AC belt, so it took me about 1 hour 45 mins on the side of the road to change it. It broke after I canceled the cruise control and was coasting which leads me to believe what Gadget has said, that the belt is prone to slipping off the idler pulley and binding up during decelerations. Gadget sells a better idler pulley that has sides to keep the belt from slipping off. I just put one of them on: http://www.urdusa.com/product_info.p..._id=1260518496 I'll let you know how well it works, hopefully after about 60,000 miles of use. The only place my water temps got a little high was climbing up into the mountains from Denver. It was about 95* F in Denver that day. The coolant temp started to get above 230* F so I backed off the speed some and it came down pretty quickly. Most of the trip the coolant temps stayed in the 205-210 F range and the oil temps stayed in the 220-230 F range I noticed on one big hill climbing up to Santa Fe my oil temp hit 250* F. So again I backed off the speed some to cool it down. I'm sending off an oil sample to Blackstone Labs for UOA today. I also got a few CELs on the trip. P0300, P0302, P0305 (flashing misfire codes) How the heck does the ECU know if there was a misfire anyway? And P0171 (system too lean code) BTW my wideband A/F gauge showed the A/F ratio to be good, not too lean at all. I suspect these were related to altitude changes or a tank or 2 of bad gas because they seem to appear only for about one tank of gas then dissappear and not come back. Still some snow up there: These jeeps were slow and didn't want to let me pass so I had to follow them up the trail. My wife's employer put us up in this nice hotel in Vail for 3 nights. It was strange having valet parking for my truck but I didn't worry about door dings with my sliders hehe.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 07-21-2008 at 10:20 AM. |
#703 (permalink) |
Sounds nice, and like it is working well for you. I will have to look at the idler pully from URD, i had seen it before but didn't know why you would want it. now i do.
__________________
Just call me TA 2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, URD 7th, 2.2 pulley, Doug Thorley Headers - My truck All the Mods that can be done to 3rd Gens Thread My thoughts on Gun control summed up quite nice: “Gun control runs aground on this simple fact: people who would use guns to break laws would also break laws to use guns” |
#704 (permalink) |
I had thought that it was mainly the 5 speed guys that had problems breaking SCer belts, but mine sure didn't last very long. It was a real PITA changing it in the middle of a vacation too. Maybe the URD 2.1" Supergrip pulley put some extra stress on it too.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#705 (permalink) |
Hey Dale, nice to see an update. You went through Santa fe without trying to get in touch with me though?!?!?!?
You suck!I get those CEL codes from time to time as well. I get the misfire code sometimes when I'm running at high boost for an extended period of time (like up a big hill). I suspect the "misfires" are due to the IK-22 spark plugs I have, since their screw tops tend to loosen up and lose connection, but every time I check the plugs they seem fine. Planning to go to the copper ones eventually to see if they help. Are you running a .032-.035 spark plug gap? Sometimes I can feel some "little misfires" also when running in high-boost even though a CEL never throws, I usually take that as a hint that the plugs are not working and need a re-gap/cleaning/replacement. As for the lean code, I get that one too sometimes when I let the engine idle for a while. Not sure where it comes from, it usually clears itself out after a few hundred miles of driving, unless I clear it first; I've always thought the ECU is whining because it has to turn the fuel trims way down to reach 14.7 AFR at idle (that idle/coast area of the fuel map it a real toughy to tune). My AFR is always fine on my wideband gauge when the CEL throws, just like yours. Wierd about that S/C belt, I'm gonna go buy myself a spare now that you've got me all scared. I like the sound of the URD idler pulley though...
__________________
Brian 1998 4Runner SR5 Last edited by mastacox; 07-21-2008 at 12:34 PM. |
#706 (permalink) |
Yeah sorry Brian, but I did think about you as I was driving through NM. We were on the flip side of a long trip and pretty tired by then.
I'm running .041 gap on those plugs IIRC (if I remember correctly). Now that you mention it the misfire codes were on long hills under higher boost. And the P0171 was during a lot of idling while 4 wheeling. I'm going back to CO at the end of the month for the CO4RJ. See the trip planning section here: http://www.yotatech.com/f15/
__________________
#707 (permalink) | |
No big deal on passing through, we do need to meet up eventually. Have you seen the new rims I got for the 4runner?
Quote:
As for the lean code, I've just learned to ignore it since I know it's fine watching my AFR gauge.
__________________
Brian 1998 4Runner SR5 |
#708 (permalink) |
Guess I'll pull the plugs and regap then. I'll also tighten the heck out of those little caps too.
New rims? I'll have to looky.
__________________
#709 (permalink) |
Hows your alt do with all the fans?
Bigblock |
#710 (permalink) |
__________________
#711 (permalink) |
That looks like the factory alt? Where did you get those numbers?
__________________
#712 (permalink) | |
Quote:
http://www.yotatech.com/f116/boyle-h...r-pics-140704/ EDIT: Here's another one with contact info: http://www.ttora.com/forum/showthrea...ght=alternator
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 12-02-2008 at 08:45 AM. |
#713 (permalink) |
Well as I posted in Raj's thread here (http://www.yotatech.com/f160/finally...2/index10.html) ,my ORS cross-over has developed a crack.
It had started to make a little noise that sounded like an exhaust leak and sure enough there was. Some others in Raj's thread had gotten it out by lowering the trans a little bit, so I tried that and it worked to get it half way out. Then I found to get it all the way out I needed to raise the tranny back up to its normal spot. Here's some pics: The crack ran along side the weld.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 12-29-2008 at 12:40 PM. |
#714 (permalink) |
I am willing to bet that crack was caused by the heat wrap. Heat wrap is bad in the long term. I amkes the headers/pipe get much hotter then it usually would and in your case the pipe was extra hot inside the wrap and then cooler in the spot that is cracked.
Wrapping it all up can still lead to cracking/warping. Had it happen on an old ford escort once.
__________________
#715 (permalink) | |
Quote:
__________________
#716 (permalink) |
__________________
#717 (permalink) |
Got it cleaned up so I can do some welding on it and it does look like the metal on the left bank got too hot. The whole right side looks good. So I'm thinking the while the wrap helped hold the heat in and basicly melt the pipe to the point of scaling over, its not solely responsable for the over-heating. After pulling the plugs I see one cylinder (closest to the firewall) on the left side is running hotter than the others. That plug tip was slightly melted, enough that it needed regapped. All the others looked normal, and even that one looked normal except for the extra wear. By pure luck my EGT probe is closest to that cylinder and just in front of the burnt section of pipe so I was seeing the hottest temp on my EGT gauge. IIRC it never got over 1500* F, usually 1450 was the max.
Pics:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 12-30-2008 at 07:35 AM. |
#718 (permalink) |
You may want to look at getting the cross-over ceramic coated to better deal with the heat. I sent mine, plus the exhaust manifolds, to Jet Hot Coatings and the coating does what it's claimed to do. After turning off the engine I can touch the manifolds after sitting for a few minutes.
__________________
"If it's worth doing, it's worth doing right" my father-in-law 1989 4wd Xtra Cab, 3.4L V6 A340F auto, gear drive transfer case, 3" Downey rear leafs, 1.5" BJ spacers, Doetsch Tech shocks front & rear, E-code Hellas 4.88 gears, ARB locked F&R, Toyo Open Country MT 255/85R/16, Procomp 16x8 black steel Krawlers Badlands Basher front bumper, Warn M8000 winch, All-Pro Off-Road rear Tacoma bumper Revenge Fabrication Sliders Alpine CDA 9857 My 3.4 swap |
#719 (permalink) | |
Quote:
Exhaust manifolds/headers should not be wrapped. That holds in way too much heat. Every header manf. that I've seen (took the time to read all the print) will void their warranty if the header is heat wrapped. ![]() Fred |
#720 (permalink) |
Hey Dale
Sorry to hear about your header. I will add that after i replaced mine back in October 2007 with the replacement from ORS, which i had cermamic coated by a guy in Colorado Springs, it hasnt cracked again. I also built a bracket out of the original 3.0 exhaust/transmission bracket. to help stabalize the exhaust and take the torque off the upper portion of the crossover. I have to aggree with most of the other people on here about the header wrap causing the problem. ORS at the time of my replacement suggested that i do 2 things and they were to brace the exhaust system at the trans, and put a flex compling somewhere before the cat if possible. Hey Fred, Sorry for arguing with u in the past about the ethanol. I didnt know enough at the time and thought i did.
__________________
~Brian GETTING FIXED 89 Ex-Cab 3.4 Conv. T100 Auto Tranny ~Phoenix 94 Ex-Cab 22re 5spd Came with parts truck. Doesnt run yet. 90 4runner 3.0 Auto (Wifes Toy) 92 4runner 3.0 Auto (Currently With Blown Engine) (New 3.4 Swap i think) |
#721 (permalink) | |
Quote:
__________________
#722 (permalink) |
on mine they taped off the coupling and coated everything else. hasnt seemed to be an issue all i have on the firewall is the stock insualation and my feet a have only gotten slightly warm on very very long trips like the one from colorado back to washington were i didnt shut the truck off for 16hours. its a hell of alot better then how warm they got when the other pipe completely failed and started pumping exhaust gas directly into the floorboard and cocked the ebrake cable and speedo cable and melted the insuation on the INSIDE of the cab.
__________________
#723 (permalink) |
My cross-over is completely coated inside and out, flex coupling included. The coating doesn't chip, flake, or crack off and it doesn't affect the flex coupling.
__________________
#724 (permalink) | |
Quote:
BTW I noticed when the muffler shop made my exhaust they flexed my coupling real good in all directions, I guess to kind of loosen it up.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 12-30-2008 at 09:44 AM. |
#725 (permalink) |
Yep. I was curious when I got it back and it flexed like it did before the coating.
__________________
| Tags |
| 34, 5vz, coolant, crossover, diagram, exhaust, kit, o2, pipe, ptr0435050, rear, simulator, swap, temp, toyota, urd, wiring |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| cant get it started | surfmobile | 86-95 Trucks & 4Runners | 4 | 01-28-2006 10:26 AM |
| HELP! Cant get it started!!! | ricky | 95.5-2004 Tacomas & 96-2002 4Runners | 22 | 07-31-2005 08:33 AM |
| 4.3 Conversion Started | 1WiCkEd_RuNNer | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 07-18-2004 07:53 AM |
| 3.4 swap getting started | the00flaw | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 12-16-2003 06:48 AM |
| Supra Swap started | NCSU-4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 19 | 11-11-2003 11:54 AM |
