3.4 swap started - Page 28 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-28-2008, 02:24 PM   #676 (permalink)
mt_goat's Avatar
That calulator says you are doing 2343 rpms at 75mph. Sound right?
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 05-28-2008, 02:31 PM   #677 (permalink)
Yeah I had the wrong gear ratios. Here are the ones I found now:
Toyota A340F Auto Transmisison
1st- 2.804
2nd- 1.531
3rd- 1.000
4th- 0.705
Rev- 2.393
With those numbers I'm pulling 2300rpm at 75mph, which sounds about right. I personally wouldn't mind having 4.56's, but the jump from 4.30-4.56 is so small that it's pretty much not worth it compared to other things I want to buy
I'm curious how much my 4Runner weighs with a full tank of gas and me in it... I'm guessing about 4500-4700 lbs but I'm not sure.
__________________
Brian
1998 4Runner SR5
mastacox is online now
Old 05-28-2008, 02:59 PM   #678 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
Brian, is there a reason you think in absolute psi? On my turbo diesel the wastegate opens at 32psi, no matter what altitude, even thou I live above sea level 32psi is still 32 psi... just like at 2-3 psi you would still be below absolute pressure, due to the altitude there is a positive flow to it. It does take more work to equal the same boost at elevation thou...
Here is a tranny chart I made...
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 05-28-2008, 03:16 PM   #679 (permalink)
I just mentioned it to Dale because our FTC's have MAP (manifold absolute pressure) sensors on them and therefore think in terms of absolute pressure rather than gauge pressure. We do have the TRD boost gauge which reads gauge pressure, but it does nothing to control our engines' tunes.
As my tune is set right now, the FTC takes over the oxygen sensor's signal at 1psi absolute pressure, which ends up being about 4-5psi gauge pressure where I live. For a while I was running it so that it kicked in at 0 psi alsolute, but the lower I go the more problems I have with the FTC freaking out on me, so at 1psi it will have to stay. Hopefully I'll get W/MI injection in the future to get a little extra oomph and to make sure my EGT's stay in line (I'll have to get an EGT gauge too, which will suck to install).
__________________
Brian
1998 4Runner SR5
Old 05-28-2008, 03:29 PM   #680 (permalink)
AH64ID's Avatar
Gotcha, yeah I figured that was it as I was lighting the BBQ.... My CTD works the same, thou in gauge pressure it always seems to open the wastegate at 32psi.. .thou thats disabled now.
EGT's are a pain thats for sure... too bad the roots style would be a nightmare, if even possible, to intercool. I know they have an aftercooler on the blower for the 4.0.
What do your intake temps look like compared to ambient?
__________________
-John
AH64ID is offline
Old 05-28-2008, 03:54 PM   #681 (permalink)
Quote:
Intake temps are essentially the same as ambient according to my OBD-II reader, I have no idea what my CDT is but it probably isn't too bad since it's relatively cold here...
__________________
Brian
1998 4Runner SR5
Old 05-29-2008, 10:35 AM   #682 (permalink)
So I looked at rpms today on the way to work, I about 2075 rpm at 65mph, and about 2400 rpms at 75mph. So the calculations based on the transmission ratios seem to be correct.
Just for fun, I whipped up a graph comparing engine/vehicle speed and 4.30 vs 5.29 gears. Seems about right, subject to some slight tire diameter error.
__________________
Brian
1998 4Runner SR5
Old 05-29-2008, 10:55 AM   #683 (permalink)
mt_goat's Avatar
Interesting graph, I think I see now why that 4runner out ran me on that hill. You have a really sweet 3rd gear that takes you to the peak of the power band in the 80-90mph area. I was lugging some in OD, he was probably in 3rd gear.
Why did you stop the graph at 100mph, lets see what your top speed would be at redline, LOL.
__________________
~Dale~
mt_goat is offline
Old 05-29-2008, 11:08 AM   #684 (permalink)
LOL, here ya go Dale. At 5500 rpm in 4th gear, I'd be doing 177 miles per hour. Fortunately, my tires explode at 122 miles per hour, and the speed limiter kicks in at what, 102?
You should definitely shift out of O/D if you want to pass with authority.
__________________
Brian
1998 4Runner SR5
Old 05-29-2008, 11:15 AM   #685 (permalink)
mt_goat's Avatar
Wow, about 145mph for me. I guess I'm not geared too low then, LOL. Can you image 33" mud tires going 145mph, I wonder if they ever hit that in the Baja 1000.
__________________
~Dale~
mt_goat is offline
Old 05-29-2008, 11:18 AM   #686 (permalink)
Texas_Ace's Avatar
Send a message via MSN to Texas_Ace Send a message via Yahoo to Texas_Ace
So with my 3.91 gears i am good for what? 200mph+?
Oh, and the speed limiter kicks in at 109 BTW
__________________
Just call me TA
2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, URD 7th, 2.2 pulley, Doug Thorley Headers - My truck
All the Mods that can be done to 3rd Gens Thread
My thoughts on Gun control summed up quite nice:
Quote:
Originally Posted by sdstud212001 View Post
Guns kill people like spoons make people fat
Quote:
Originally Posted by Dare44 View Post
Im a firm believer in the saying "If you outlaw guns, only the outlaws will have them"
“Gun control runs aground on this simple fact: people who would use guns to break laws would also break laws to use guns”
Texas_Ace is offline
Old 05-29-2008, 11:24 AM   #687 (permalink)
mt_goat's Avatar
Quote:
You found that out huh? BTW there is a way around that limiter, URD used to sell the little gadget to do it. I guess their lawer told them to quit selling it.
__________________
~Dale~
mt_goat is offline
Old 05-29-2008, 11:26 AM   #688 (permalink)
Texas_Ace's Avatar
Quote:
LOL, i never said that..........
And yeah i have heard there is a way around it, depending on price i might do that just for when i dyno it as the speed limiter kicks in at about 5000 RPM and there is still 1k rpm to go. We will see.
__________________
Just call me TA
Old 05-29-2008, 11:26 AM   #689 (permalink)
BFGoodrich Baja T/A's are "T" speed rated, 124mph. I doubt trophy trucks get up past 110 miles per hour much in the Baja.
Quote:
Originally Posted by OffRoad.com
[37" Baja T/A]...highest in the industry 124mph "T" speed rating, it pulls as much as a 30mph safety margin over the competition...
...It takes a tough tire to run for 30 minutes at 140mph across a 120 degree dry lake bed. And this is toughness that is built into every Baja T/A.
__________________
Brian
1998 4Runner SR5
Old 05-29-2008, 11:30 AM   #690 (permalink)
mt_goat's Avatar
Cool
__________________
~Dale~
mt_goat is offline
Old 05-29-2008, 11:34 AM   #691 (permalink)
mt_goat's Avatar
That may be the only way I'll ever hit 109mph, sitting on a dyno, LOL.
__________________
~Dale~
mt_goat is offline
Old 05-29-2008, 11:37 AM   #692 (permalink)
So Dale have you determined if you have a narrow-band O2 sensor or a wideband O2 sensor yet? I hear URD is working with SplitSecond on a new ESC unit that will work "perfectly" with Toyotas that have narrowband sensors, I may have to look into getting one...
__________________
Brian
1998 4Runner SR5
Old 05-29-2008, 11:43 AM   #693 (permalink)
AH64ID's Avatar
Any plans to run it on the rollers?
__________________
-John
AH64ID is offline
Old 05-29-2008, 11:46 AM   #694 (permalink)
mt_goat's Avatar
Not for sure, I haven't taken it out to look. Everything points to it being a wideband though.
I still run in open loop a lot just cruising down the highway. Most of the time its just slightly rich though, like around 13.9-14.2 area. Although I did have one little scare in the middle of my trip cruising along about 65mpg, very low throttle and I see my A/F like around 11 and dropping. I was like WTF??? I let off the gas and coasted then went back to speed and everything was fine after that, it never did it again. Maybe it freaked out like yours huh?
__________________
~Dale~
mt_goat is offline
Old 05-29-2008, 11:51 AM   #695 (permalink)
mt_goat's Avatar
No plans, it would be nice sometime though. Not sure if there is even a place to do it around here.
__________________
~Dale~
mt_goat is offline
Old 05-29-2008, 12:01 PM   #696 (permalink)
Yeah, "tricking" our engines into doing what we want is always an imperfect science...
I still want to look into an SMT7 to replace my FTC1. The SMT7 uses wideband O2 input for tuning, so your fuel map is a bunch of AFR values rather than fuel trims. You just tell it the AFR to aim for and it does what it needs to get there I guess. Sounds pretty frickin' sick, and it has two hot-swappable maps so you could run agressive and conservative maps. In theory it also can control a 7th injector, so I might be able to use it to control a W/MI kit as well...
__________________
Brian
1998 4Runner SR5
Old 05-29-2008, 12:07 PM   #697 (permalink)
mt_goat's Avatar
Now that sound great! Why don't you lead the way Brian.
__________________
~Dale~
mt_goat is offline
Old 05-29-2008, 12:18 PM   #698 (permalink)
Texas_Ace's Avatar
What he said, i am interested as well now that i am about to join ya'll in the SC club.
Of course first i need to get it rebuilt and installed....
__________________
Just call me TA
Old 05-29-2008, 12:51 PM   #699 (permalink)
I want to, but it won't be for a while yet. It would be totally sweet if I could find one for cheap used, but for now I'll just have to stick with what I've got. It might be possible to fake out the oxygen sensor using one of the analog voltage ouputs on the SMT7 (14.7 AFR on a narrow-band oxygen sensor is just a constant 0.50 Volts, nothing too complicated about that), but more likely I will need to wait until SS comes out with their "ESC-2.0".
I do think I'm going to get an SMT7 rather than go full data acquisition however, since they both would cost about the same (actually data acquisition would be more $$$) and are both to try and solve the same problem- easier tuning with the possibility of upgrades later on. Supposedly you can get a base-level standalone engine management kit from Megasquirt for close to the price of an SMT7, but going standalone would be biting off a lot more that I would want to chew I think...
__________________
Brian
1998 4Runner SR5
Old 06-30-2008, 07:28 PM   #700 (permalink)
mt_goat's Avatar
I made a support bracket for the down pipe today. There have been a few guys having problems cracking the crossover so I wanted to help support it and hopefully avoid that problem. Toyota has the down pipe supported in this area from the factory so maybe they know best. In fact I made this bracket from an old factory bracket.
__________________
~Dale~
mt_goat is offline
Tags
34, 5vz, coolant, crossover, diagram, exhaust, kit, o2, pipe, ptr0435050, rear, simulator, swap, temp, toyota, urd, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
cant get it started surfmobile 86-95 Trucks & 4Runners 4 01-28-2006 10:26 AM
HELP! Cant get it started!!! ricky 95.5-2004 Tacomas & 96-2002 4Runners 22 07-31-2005 08:33 AM
4.3 Conversion Started 1WiCkEd_RuNNer 95.5-2004 Tacomas & 96-2002 4Runners 11 07-18-2004 07:53 AM
3.4 swap getting started the00flaw 95.5-2004 Tacomas & 96-2002 4Runners 15 12-16-2003 06:48 AM
Supra Swap started NCSU-4runner 95.5-2004 Tacomas & 96-2002 4Runners 19 11-11-2003 11:54 AM
2009 InternetBrands, Inc.
