| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#501 (permalink) | ||||||
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#502 (permalink) |
The radiator came from my local shop "Spikes Radiator" it was in a modine box. It was installed 2 weeks ago. I might try to buy one for grins, i'll let you know.
FWTW.... Modine doesnt seem to make radiators, they just are a low cost supplier that rebadges whom ever is the low cost bidder/builder at the time |
#503 (permalink) | |
Quote:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 05-25-2007 at 10:58 AM. |
#504 (permalink) |
Well I decided to do plans B3-B6 all at the sametime to save on my labor. I found the aluminum core Proliance radiator (#432272 for my truck) at www.rockauto.com for $135.79 + shipping so I got one coming. That's the good news, the bad news it has plastic tanks and only a one year warranty on it. Maybe it will last longer since I'm converting to a waterless coolant the radiator pressure should stay very low, I could even run a zero pressure system if I wanted to.
__________________
#505 (permalink) | |||||||
Quote:
![]() Quote:
![]() Quote:
I wouldn't bother with this, unless it's a short-term thing until you get a new radiator or bumper. Running hotter than normal will still give your ping difficulties and could still possibly damage things in the engine. Quote:
Quote:
Quote:
Quote:
![]() This seems like something worth looking into, I would try it before going through the trouble of relocating coolers and such.
__________________
Brian 1998 4Runner SR5 |
#506 (permalink) | ||
Quote:
Quote:
http://www.custommachiningusa.com/Evans_NPG+.html Maybe it would help you with your knock problem. I have removed the little strip of rubber at the back edge of the hood but I haven't tested it out yet. One radiator guy I talked to about a custom radiator wanted me to do one test first before building a custom rad. He said to remove the hood and test drive it because sometimes the air gets packed up inside the hood at higher speeds. I thought that was interesting but I haven't tried it yet.
__________________
#507 (permalink) |
I personally am a BIG believer in the aluminum radiator, not b/c of my truck tho...
I've got a 68 stang that I built a stroked 351 windsor for (393 inches now) that has a "healthy cam ", high compression, headers, and all the good stuff to make it run hot. I put in a 4 row brass/copper radiator at first and even when I had no hood on it, if i let it sit it would overheat easily. I've got an electric fan setup on it that kicks on at 180 and kicks back off at 160 that was on both my old radiator and this new one. Now with the 2 row aluminum radiator that I got and the hood on it will kick the fan off because the coolant temp is getting to low. I love it and wish that I had it before I was trying to mess with everything else |
#508 (permalink) |
About all you're going to accomplish by removing the rubber strip at the back of the hood is sucking hot-@$$ air into your climate control & onto you. I ran my truck two days ago without the hood & it didn't make one iota of difference in the temp. Do you have headers? They have a TON of surface area & emit a boatload of heat...
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ |
#509 (permalink) |
Good to hear that Jason, can't wait to try that aluminum radiator. (BTW how's the eye doing)
Rabbit, I hadn't thought about the vents, although I usually run with those closed. I can put that strip of rubber back on later, its held on with 3 screws and 2 plastic push pins. Here's another good reason to bypass the factory radiator ATF cooler: http://www.yotatech.com/showthread.php?t=116812
__________________
#510 (permalink) | |
Quote:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 06-05-2007 at 10:16 AM. |
#511 (permalink) | |
Quote:
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. |
#512 (permalink) |
Wow, great job on the swap and all the documentation of the details. This will defiantly help people who run into some of the same issues that you have encountered. I hope you get your overheating issue resolved soon; you might want to try removing the bumper and see if it has any affect on your temp. At least it could point you in the correct direction. If you are in the area feel free to come by, we would love to have a look at how the swap worked out for you.
__________________
Off Road Solutions Arvada, CO 303-278-6267 www.offroadsolutions.com Offering offroad products, engine conversions & custom fab work for your Toyota (& much more...) |
#513 (permalink) |
Thanks Mike, I'm going to be in Co. Springs in July and Buena Vista in Aug. I'd love to see your shop sometime.
__________________
#514 (permalink) |
Well after waiting another 5 days... Rockauto.com sent me another copper/brass radiator, and now they say they can't get an aluminum one. They did pay for the shipping to return it though (after a little convincing). So scratch that earlier glowing endorsment I gave.
That's the bad news, but the good news is I got one from Summitracing.com, for $180 shipped and it came today. Same part number and manufacturer as the other one, (Proliance radiator #432272) but this one came straight from Proliance. Here's some pics:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 02-02-2008 at 04:24 PM. |
#515 (permalink) |
Hope you get that in soon... I wanna see results...
As far as temps, I have a SGII and have been watching mine a little closer.. Last weekend in 80-85* with 500lbs in the bed and a 1500+lb trailer the max I saw was 198* on a long steep pull in 3rd at 4K at 70mph... This week in 95-100* heat with no trailer and 300lbs in the bed the temps were 196-198 on flat ground doing 75, constant.... I have yet to see over 198.. Driving 75 with a fairly empty bed on a 70-80* day only gets me 189-191..I know its a different motor and n/a, but its a stock toyota setup... so I would assume the temps are pretty normal...
__________________
#516 (permalink) | |
Quote:
__________________
#517 (permalink) |
ScanGauge II, it's an OBD-II reader.
__________________
#518 (permalink) |
Oh....thanks Brian.
__________________
#519 (permalink) |
I don't know if this will help you Dale but I finally figured out how to get my engine to consistantly run around 180* and have the taurus fan only use the low speed. Today the temp was 86* plus high humidity and all was good to go. I removed the stat alltogether.
Here is why I think this works even though it shouldnt': Normally the engine uses a belt driven fan that turns all the time and pushes a lot of air. As the engine warms up the stat stays closed till it hits the opening temp (180* in this case) This allows coolant to flow through the high density rad thus cooling the coolant in the engine, allowing much cooler fluid from the rad into the engine combatting rise in temp and slowing it down. As temps increase more cool fluid comes from the rad etc up to 200* degrees at which point if your temps don't come down then the engine overheats. With my truck the electric fan only runs when temps come up and pulls less air then the stock fan. So with a factory stat cool coolant only comes into the engine above 180* and since there is less air movement the coolant is warmer then it would be under the factory system, meaning it does less to combat the building heat. Only when the temps reach 200* does the maximum amount of cooling potential reach the engine at which point its already getting too hot etc. When I remove the stat the coolant circulates constantly (which means warming up the engine takes a bit longer) But now my fan controls engine temp. Does this at all sound silly? SO far its the only thing that is working. I think If I use the TRD stat that is fulling open @ ~175 I should be ok but this is working for now.
__________________
89 v6 SWB truck *PROJECT "BLACK BEAUTY* P&P heads, EB's OS SS valves,30 over on the bottom and deckedto zero, taurus fan mod. |
#520 (permalink) |
Nope, makes sense to me. I was suprised just how small the opening was on the t-stats I tested. They really seem to create a bottle neck for coolant flow unless they are fully open and some I tested didn't get fully open until 212 degrees F. And to make matters worse on the 3vz and 5vz engines the t-stat is on the return line from the radiator. That means the coolant flow from the radiator must be very hot to keep the t-stat open all the way.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 06-12-2007 at 08:50 AM. |
#521 (permalink) | |
Quote:
). First thing I noticed is the light comes on a lot, even though I'm not hearing any audible knocking. But it does seem to light up in the areas that pinging would normally be a problem, like low RPMs around 0 boost and under WOT. (And yes I'm running premium gas). So, I set the sensitivity level to the lowest possible and I test drove it. That caused the light to stay off a little more, but it still shows quite an alarming amount of pinging. So I guess (if I can believe this thing), I must have a lot of knocking I need to tune out. I have yet to mess with the FTC map B that URD sent me because I hadn't heard much knocking at all, just a few times.
__________________
#522 (permalink) |
Goat,if you can hear it ;it's really bad!
#523 (permalink) |
Quote:
Mmmmm, that's interesting because on Summitracing's web site, when pull up that part number(which is correct for the 3.0 truck and 4Runner), they says it's a copper and brass. ??? ![]() Fred |
#524 (permalink) | |
Quote:
__________________
#525 (permalink) |
Yeah, the sales guy called Proliance for me to see if the current production was aluminum or copper/brass. I guess they just started making them in Al and haven't updated their site.
__________________
| Tags |
| 34, 5vz, coolant, crossover, diagram, exhaust, kit, o2, pipe, ptr0435050, rear, simulator, swap, temp, toyota, urd, wiring |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| cant get it started | surfmobile | 86-95 Trucks & 4Runners | 4 | 01-28-2006 10:26 AM |
| HELP! Cant get it started!!! | ricky | 95.5-2004 Tacomas & 96-2002 4Runners | 22 | 07-31-2005 08:33 AM |
| 4.3 Conversion Started | 1WiCkEd_RuNNer | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 07-18-2004 07:53 AM |
| 3.4 swap getting started | the00flaw | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 12-16-2003 06:48 AM |
| Supra Swap started | NCSU-4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 19 | 11-11-2003 11:54 AM |
