YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-17-2008, 09:37 AM   #1 (permalink)
3.4 Swap Done - 94 4runner/96 Taco 3.4 2wd
I started up my 3.4 swap for the first time on Monday, 2/11/08.
I have a 1994 4runner that had 226k on a 3.0 when the HG failed on 12/16/06. I put in a '96 Tacoma 3.4 2wd. The motor had 98k on it. I used the ORS complete conversion kit. ORS is a great company and they couldn't have been more helpful. Many thanks to Mike and the crew.
I turned the key for the first time a few weeks before that. The ECU was bad, so no go. Very disappointing, at the time. The new (used) ECU resolved the issue. Toy Connection in Santa Clara, CA (Thanks, Jeff) picked up the tab to replace the ECU, even though I was way past their warranty period.
It was a long time coming. It should have cost less. It was well worth it. The power increase is remarkable. Wish me luck at the CARB smog referee on 2/29.
I am part way through polishing up my notes and journal about the experience. I'll write up what issues I had and what I would do different in the near future. I learned a lot, had a bunch of fun, and a lot of aggravation doing it.
I used a K&N FIPK intake system, the ORS crossover, and a 2.5" exhaust. The Cat is a Magnaflow 46006. The muffler is a Magnaflow 12256. Sounds really nice and not too loud.
As of this writing the Innova 3100a OBDII code reader I am using is showing all is good, except the CAT. I am not getting any DTCs. I am told by Magnaflow that it may take 5-15 heat cycles and a few hundred miles for that to clear.
The other issue is that the AC fuse blows as soon as I push the button in. The green light stays on for about 1/2 second, then poof, the fuse blows. Any ideas?
funjumper is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3.4 Swap '94 4Runner - 96 Taco 5vzfe funjumper 86-95 Trucks & 4Runners 40 01-03-2008 09:33 PM
converting 2wd to 4wd 04 taco White93YJ The Fab Shop 5 02-02-2006 10:27 AM
5VZE 3rd Gen 4Runner / 4th Gen Taco Fan Swap bamachem 95.5-2004 Tacomas & 96-2002 4Runners 3 07-14-2005 04:56 AM
Will a taco 3rd member fit a 1999 2wd 4runner rear Blackulua 95.5-2004 Tacomas & 96-2002 4Runners 3 04-01-2004 03:04 AM
What can I do (aftermarket) to my '03 4cyl. 2wd Taco? Jacobi 95.5-2004 Tacomas & 96-2002 4Runners 11 07-29-2003 09:11 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
