3.4 swap with abs delete. What hose to use?
Ive done a 3.4 / one ton swap and have deleted the abs actuator. What hose are you guys using to do this. Im thinking there must be a vendor that sells a hose for this but couldnt find one. The hydraulic shop around here couldnt make one with the banjo fitting for the pump.
There are none around here, I would know as my dad has a toyota specific srap yard and we've never seen any in a decade. Ive seen evoltas build though and he sees to have a solid solution that im going to try out.
