3.4 engine swap need advise
I have a 95 Toyota Tacoma 4X4 with a 3.4 liter V6. It has a standard transmission with 375k. It has a blown head gasket so i am going to pick up a used motor from a 98 4Runner. It is a 3.4 V6 with 150k. The 4Runner has a Automatic transmission. Besides the flywheel that needs to be switched out, is there anything else that I need to be aware of when switching it out?
You pretty much have everything you need from your original truck. You'll end up swapping your old stuff over to the newer motor so you won't have to do anything to the harness or ecu. Like Vital said, the throttle body and stuff. Besides that, the only thing I'd worry about is whether or not either of them have an EGR system.
steve miller
10-10-2015 01:40 AM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
