YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-28-2008, 04:18 PM   #1 (permalink)
Hophead's Avatar
Question 3.4 ecu
As I have posted in other threads, my swap has hit a snag- the engine runs but really rough, runs well in open loop and I am getting a cnstnt 11volts at my OBD data port....I have checked my wiring many times- I think the ECU might be toast. SO I got a buddy topick me up another ECU from the local toyota wrecker but it is a 1998 4runner 4x4 M/T where as my stuff came from a 1999 Tacoma 4x4 M/T. From what I can tell it should be similar enough to run? THe full FSM I have covers 1998-2000. Anyone know for sure?
__________________
1992 4Runner -33x12.5 BFG AT's - 3.4 Swapped
Hophead is offline
Sponsored Links
To remove this ad, register today!
Old 07-28-2008, 05:09 PM   #2 (permalink)
Belize Off Road Team's Avatar
Send a message via MSN to Belize Off Road Team
NO, 96-98 are different from 99+
You will also need the harness to go with that 99 ECU.
If you do replace your 3.4L harness/ and the 98 ECU......how much????
__________________
-Phyl
1991 Hilux Surf SSR-G Petrol 3.0L V6 193,000kms l 3.4L V6 264,000kms to be rebuilt then installed! l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Drop in filter l PP 1" Lift Coil Springs l TRD shift knob l Lv. 3 First Aid Kit l White Gauges & Temp Controls l LED conversion l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l
TOYOTA TOUR 2008
トヨタ|NEVER QUIT
Belize Off Road Team is offline
Old 07-28-2008, 05:27 PM   #3 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
Are the pins the same ECU wise??? the only way to tell that is to look at both schematics for both the older and new harnesses and see what the pins are. If they are the same then you can use it if not your gonna have to either pin them out to work or get a new harness. That also depends if the plugs are the same. Also one thing that is gonna hold you back using a different ECU is the sensors. Are they the same??? I bet not. Toyota changed things just about evey two years thats why getting a running donor rig is the BEST thing to get when doing this swap. For how easy things bolt right up the 3.4 can be a pain in the a$$ and quote the "$$" part
Good luck. Hope it all works out for you
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 07-28-2008, 07:26 PM   #4 (permalink)
Hophead's Avatar
Ya I know what you speak of.... the mechanical side was easy, enjoyable actually...the wiring has been a pain. I got everything originally from a '99 tacoma ( supposedly running) but I think the ECU I got was pooched- I am confident in my wiring but it runs like a$$ and the red flag to me is when I hooked up the OBD port I get 11volts constant at the datalink wire. SO I grabbed this 98 4Runner 4x4 M/t ecu up today - plugs are the same and in the Tacoma FSM I have it puts 98,99,00 years together - my understanding is 95.5-97 is 1st gen, 98-00 is 2nd gen and 01+ is 3rd gen. At the wreckers I saw a 97 ECU - totlly different plugs. I am trying to download a 98 4runner FSM to compre pin outs right now....
If this ECU is no good to me I would let it go - I payed $175can for it...
__________________
Hophead is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Ecu 3.4l 95pinoyT4R Items Wanted 6 02-08-2008 03:39 PM
Ecu 95pinoyT4R 3.4 Swaps 4 02-06-2008 10:46 PM
ECU for 3.0 neoworm0 Items Wanted 3 12-09-2007 06:18 PM
Where is the ECU? Vtec_Killer 95.5-2004 Tacomas & 96-2002 4Runners 4 01-21-2005 08:54 PM
Ecu?? NX Tacoma 95.5-2004 Tacomas & 96-2002 4Runners 2 04-19-2004 11:10 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
