I have been studing every thread, studied my EWD, and I still can't get the engine to keep running.
The specs:
1989 3.0 MT truck
2000 AT 3.4
R150 trans
AT Harness
MT or AT ecu I have both.
I also have just bought a 2001 MT ECU and complete Harness but it is still in the mail and I need it to run by Friday.
What it does:
Fires up and will run for about 4-5 seconds.
If I gas it it die right away, choking it does nothing.
I am at work and can't remember the wiring.
I have talked to a fellow member and has suggest a few things.
I should have 3 browns to splice from the 3.4 but I can only find 2.
If I connect the 3.0 G-Y to the 3.4 G-Y the fuel pump should work, it won't with it connected like this. It will if I ground the 3.0 G-Y. Also If I put power to the large B-W coming from the 3.0 it will run the fuel pump.
Also not sure if this could be an issue but I am bypassing the the starter to the 3.4 relay and am using a different switch for that and am using the key for all the ing power.
Also have the AT Harness on it for now with the shift position sensor plugged in, and at N.
Oh and it need to drive by Friday.
