YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > 3.4 Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-15-2008, 07:54 PM   #1 (permalink)
neoworm0's Avatar
2000 4runner Air Box question
I have an airbox and all the related piping from a 2000 4runner. I would like to use the intake tube and MAF sensor tube for my swap but the air filter housing itself is broken.
I have seen a lot of people just use a cone filter on the end of the stock tubing. I can see how that is easy with the older intakes but on mine the MAF housing tube is integral with the airbox. I can't see any way to remove it from the airbox itself.
Anyone else run into this problem. I've thought about cutting it off but it doesn't look like it will leave much left to mount the cone filter. Thanks.
__________________
1995 Toyota PU SR5 V6, A few mods.
neoworm0 is offline
Sponsored Links
To remove this ad, register today!
Old 04-15-2008, 08:05 PM   #2 (permalink)
toytech76's Avatar
What is broken? Can it be fixed with a plastic welder?
__________________
97 Runner. 3" revtek front with 1/2 added spacer, front 97 LC coils and shocks in the rear, 33x12.5/15 Pro Comp mud terrains, 15x8 Pro Comp 1069 alloys, 00 runner headlites, clear corners and bumper lenses, 00 runner airbox/MAF conversion, Reverse indiglo gauges, 5000K HID's, LC hood struts, Magnaflow exhaust, custom grill insert, hella driving lights converted into headlight highbeams, retrofitted avalon homelink sunvisor.
toytech76 is offline
Old 04-15-2008, 08:35 PM   #3 (permalink)
neoworm0's Avatar
The runner was involved in a rollover and the lower mounting arm on the box broke off and took a big piece of the box with it. I didn't get the mounting arm with it otherwise I might try to fix it.
So I guess the short answer is no.
__________________
neoworm0 is offline
Old 04-15-2008, 09:22 PM   #4 (permalink)
jasond's Avatar
I cut mine off of a broken airbox and put a cone filter on it. It wasnt a big deal.
jasond is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
95 4runner air-box removal an intake upgrade widespreadconfuzion 86-95 Trucks & 4Runners 2 09-06-2007 03:16 PM
WTB - stock air filter box for a 2000 3.4L Runner bosco659 95.5-2004 Tacomas & 96-2002 4Runners 0 03-06-2007 06:13 PM
96-98 4runner air box and stock intake 98runn'n Items Wanted 0 04-07-2006 01:32 PM
Air Box and Intake Question YotaTruck1986 95.5-2004 Tacomas & 96-2002 4Runners 7 08-03-2004 06:54 PM
Will a 96 4runner air box fit in a 2000 4runner? dexter 95.5-2004 Tacomas & 96-2002 4Runners 3 03-22-2004 07:47 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
