1992 4Runner 3.4 Swap Running Thread
Thank you so much for this information! I'm getting ready to buy my donor engine and harness and I was going to buy a 97 4Runner engine and harness but I'm going to make sure I get the T100 harness instead.
So just to make sure, you're using the T100 ECM and harness with the 4Runner 3.4 right?
I just got my conversion harness and crossover pipe back from toyonly so I will be back at it FINALLY. I wanted to share my costs so far so anyone looking to do this can get an idea of the cost of the swap.
#25
Looks like you are coming along well.Cool swap. I am glad I used a manual trans on my swap (alot less wiring). Another thing you may end up needing is the power steering line mod. That one caught me off gaurd at the end of my swap
#26
say what? I have not read that at all. Where do you get that particular mod?
#28
The connection on the 3.4 pump is different than the 3.0 the flange is in a different direction and the vaccum advance module and hookup is different. I read a few where guys were taking them from donors and or having them made. I am not sure on the 4runner to 4runner mine was a t100 to 4runner. I used a pipe cutter to cut the end off my 3.0 line from the rack and I cut the one that supplied the 3.4 and used a 10mm compression fitting I ordered from Mcmaster Carr. I put 200 miles on so far without any troubles. Poke around here and you will see some of the other guys solutions. Happy Wheelin
#32
I am selling this as it sits. I'm now in Bowling Green, Ky. I will deliver within 50 miles. Asking $1000 for it all. What you have read in here is what is done.
#34
Nope sure didn't. Got it to the point of the engine being ready to drop in. Switched jobs and moved from OKC to Kentucky and just found I have no time to finish it. I'd just rather have wheels and tires for my tundra so someone will get a great deal.
#35
Well dang! I'm in the process myself of doing the swap. Currently just yanking all the old out of my runner and getting the engine bay prepped for when I have an engine. Too bad your so far from oregon.
Whitemoneypit
20
11-01-2015 10:20 AM
XtremeOff-Road
16
06-27-2002 07:32 PM
