| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Will the height adjustment of the clutch pedal affect the wear of the clutch?
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD |
#2 (permalink) |
It could if the clutch didn't engage all the way when the pedal was released. I mean if the clutch didn't engage fully when the pedal was let out. It would aslo not be good for it to be at the bottom of the pedal (floor) because then the clutch isn't fully dissengaged, which could lead to premature wear on the transmission.
__________________
Will WabFab Off-Road, LLC Toyota 4x4 Parts and Custom Fabrication updated website with lots of new products 87 runner with every bolt on available |
#3 (permalink) | |
Quote:
Thanks Will. BTW, do you measure from the carpet or from the metal floor? Also, I've noticed you've got an '87, what is your height adjustment and do you know if it's the same for an '88? Troy
__________________
#4 (permalink) |
To tell you the truth, I never really measured it. As long as it is off of the floor and not at the top of the pedal, I never really worry about it. I do like my clutch to be in the middle of pedal movement. I f you can get it there, you will be fine. Once you get the clutch bled and ready to go then adjust the pedal (under the dash) and fine tune it to the way you want. The adjustment should be the same for 87/88 4runners.
__________________
#5 (permalink) | |
Quote:
My clutch seems to disengage about 1/3 from the top of full pedal height. I'm currently experiencing minor clutch slippage during hard acceleration, but didn't haven't any problems with slippage about a couple of weeks ago. The pedal height was adjusted about 2 to 3 months ago. I think it maybe time for a new clutch. I guess I thought it would last longer... Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD Last edited by YotaJunky; 11-21-2005 at 04:58 PM. |
#6 (permalink) |
I don't know Troy, with all those clutch problems maybe it's time to get an auto
#7 (permalink) | |
Quote:
I'll pm you and if you've got time, and that tranny jack available, please let me know. It's great to know you're still on Yotatech Eric. Troy
__________________
| Tags |
| 4runner, 784, 96, adjust, adjusting, adjustment, bottom, clutch, engages, floor, height, pedal, problem, release, releases, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problem with clutch/clutch pedal | bpina4813 | 86-95 Trucks & 4Runners | 8 | 01-12-2007 08:38 PM |
| Clutch grinding, poor shifting, cracked clutch pedal bracket | T100NewMexico | 93-98 T100s | 10 | 09-22-2006 01:31 PM |
| Clutch pedal/clutch problem: help needed | p.m.coupe | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-04-2006 02:18 PM |
| Best Clutch Pedal Height for Off-Roading | AKennedy87 | General Vehicle Related Topics (Non Year Related) | 2 | 01-20-2006 08:43 AM |
