| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
when to change battery?
__________________
2003 V6 SR5 4x4 OME 3.5" Lift Revo AT 265/70/17 Magnetic Vinyl paint protection during off road |
#2 (permalink) |
You can take it to Sears, Advance, Autozone, etc and they have a tester that puts it under load and tells you the condition of the battery and alternator.
Or get a AAA membership and don't worry about it...
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#4 (permalink) | |
Quote:
You need to load test it to verify a good battery.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#5 (permalink) |
Personally, I'm 100% sold on AC Delco batteries from my local GM dealer to the tune of $70. They're sealed batteries/maintenance free and have their gas vents directed to the side to prevent terminal corrosion. They fit perfect every single time even in my Toyotas and I've never seen one spontaneously fail. Buying a good brand is half the battle. I believe that to be a good battery it must fit good too. None of those adapters or universal pieces of crap with the terminals in the middle that make you stretch your battery cables. A well secured $35 battery with the terminals in the right place will absolutely outlast a $120 battery that doesn't fit right and vibrates around the battery tray and yanks your ground cable off the interior fender well.
#6 (permalink) |
A battery can fail at any time. Most of the time, however, you can tell if it's degrading if you pay attention (and if you're lucky). Cranking speed on cold mornings is probably the most blatent indication. Another is how dim lights get when the engine is cranking or when you're sitting at idle with other heavy loads turned on.
Todays batteries have improved longevity compared to those made 10 years ago. Most decent batteries will last 4-5 years, easy. But there are a lot of variables and you simply need to watch for signs. If you're uncomfortable, replace the battery every 3-5 years and don't worry about it. Batteries are cheap.
__________________
'00 SR5, Desert Dune: 4" Deckplate, Amsoil TS-115, Bilsteins, Brembo rotors w/Performance Friction pads, Fiam Highway Blasters, Sylvania Silverstars, Hella Micro DE Fog Lights w/Hella Yellow Star Lamps - SOLD 1/24/09 '08 Sport, Salsa Red: Hella Optilux fogs, Silverstar Ultra Hi beams. Pending: Borla dual catback, CAI, shocks |
| Tags |
| 4runner, batteries, battery, battries, change, changing, check, dim, drain, drop, free, idle, lights, load, low, maintenance, replace, toyota, trail |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Battery, Battery, which one to pick... | Texas_Ace | 95.5-2004 Tacomas & 96-2002 4Runners | 60 | 05-09-2007 09:08 AM |
| How much to change battery wires? | ken.vs.ryu | General Electrical & Lighting Related Topics | 8 | 11-20-2006 06:35 PM |
| new battery | Chapman88SR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 10-17-2004 06:02 PM |
| Coolant change, belt change help needed on 94 Toy Truck 4 cyl 2 wd | BravestDog | Maintenance & Repair Archives | 2 | 05-16-2003 11:11 AM |
